Thank you! Finally a sensible prose on the situation and confirming I'm not going utterly insane.Filtration is pretty meaningless, because filtration removes particles and we don't have (m)any. What we have is a solution of resin in IPA.
I think the only use of dirty IPA is precleaning in a two-stage washing process.
Michael
3D Resin is a liquid, it's very hard to separate it from IPA because they're homogeneous, a filter will remove particles of cured resin or broken supports but they do no harm in the solution at all, we're not spray painting with it.
If you really must try and clean your IPA then decant it into a clear jar, preferably glass and seal it, stand it outside and the majority of resin will migrate to the bottom and harden in the natural sunlight. When clear decant the liquid and use again, but, chances are it will have an oily slimy feel to it. A quick test is to smear some on a resin part and blow quickly over it, if it dries matt, it's good to use, if it's satin or gloss then it's still impregnated and junk.
For what it's worth, it took my jam jar test several weeks to clear up and even then the resultant IPA was not good enough to clean prints and left a tacky glossy finish to the parts.
I like Adrian's idea, reuse it in garden heaters, brilliant solution and I get to enjoy it's twice. Mind I'd leave it to settle in the sealed clear container first before using it; the resin that does remain might clog up the ceramic burner, depends how big the ports are.
