Hi all,
Things in my personal life have taken an unexpected turn recently which has severely limited motivation and time. But despite this, and as it so often does, modelling has provided a welcome distraction.
This Bachmann BG was my final purchase from Hattons [RIP] before they closed and it will become a key item of stock, being the centre of a 3 coach train for my future [now far off future] layout.
Although I generally like Bachmann Mk1's, there are a few areas I'm not so keen on so I've endeavoured to use this as both a test bed and benchmark for all my eventual coaching stock.
I don't like the overdone roof ribs on some of the older Mk1's - so I'll sand these [and the periscopes] off as per the CK I started ages ago [paused and back in it's box!]. I also don't like the moulded brakeshoes that are not in line with the wheels. I initially planned to remove them and reposition them more appropriately, but in the end decided it was likely to be more effort than it was worth. I subsequently decided to use Rumney Models bogie subframes and I'm very glad I did!
All the end detail has been removed as per the prototype photos I'm using and the grab rails replaced with wire [I also replaced the bodyside handrails at the same time].
I've also stripped the original paintwork [this is actually what it looks like underneath!] as it'll eventually be repainted blue/grey.
It's taken me the best part of 2 months to get to this point. With regards the bogies, they run beautifully smoothly and note that I've shortened and reused the Bachmann sideframes [you can see the joint below although not really visible at normal viewing distance].
I'll be reusing the original glazing - I did purchase some flush glazed replacements but have decided, mainly for convenience, to reuse the originals. I've also soldered up some simple bufferbeam footsteps, but I'll leave these off for now as they're prone to being bent accidentally.
Thanks for reading!
Matt
