Very pleased to read about your EM baptism, Matt, and may I wish you all the best with your venture.
I’ve dabbled with P4, and that’s about it, mainly because I find it difficult to commit to any single project as my multitude of threads will bear witness, rather than encountering hurdles that couldn’t be surmounted with a little faith, even for a modeller of my limitation.
I recall dipping my toe by purchasing a set of gauges, much like yourself Matt, with which I fashioned a turnout or two from simple PCB sleepers and lengths of bullhead from C&L, and it was a delight to see that they worked first time (the test consisted merely of me gently blowing a set of P4 wagon wheels across the frog and switch blades which rolled freely back and forth without any hint of the dreaded wheel drop). I then progressed to a turnout kit from C&L using butanone to ‘glue’ the chairs to the sleepers, which again, worked surprisingly well (although I preferred the robustness of the simple PCB version as the plastic kit developed a noticeable twist when moving the blades, although I figured that this would be eliminated once fixed down to the board. Sadly, I never got any further with a layout to test the theory).
I even got as far as rewheeling a wreck of a Bachmann pannier, bought cheaply of an internet auction site for the purpose, with Ultrascale wheels, which came ready fitted to their axles, which was surprisingly simple, despite the added complexity of resoldering the Bachmann coupling rods onto the wheels; but I needn’t have worried, an oil dipped section of fag paper assisting admirably. To my surprise it worked:
Seen here on a length of Peco flexi track cut in half then spaced to 18.83 using said gauge as I was out of track ( was this really a serious foray into P4?
![Roll Eyes :rolleyes: :rolleyes:](/styles/default/xenforo/smilies/rolleyes.png)
) Considering the wreck of a donor, use of an old DC controller and the fact I hadn’t even done the construction justice by attempting to oil anything prior (I was just too keen to see if it worked), I think it worked okay.
Then I went on to build a ‘sector plate’ based on that at Snow Hill, from an old door and bits n bobs lying around the modeling den, and gluing together a left and right hand paper template left over from the C&L kits mentioned earlier, upon which it was constructed. Surprisingly, that worked too, but has progressed no further from the image you see here:
Shane, really.
Anyway, apologies for hijacking your thread, Matt, but just to show that even the ‘odd mortal’or two (me, not you
![Wink ;) ;)](/styles/default/xenforo/smilies/wink.png)
) can at least broach the scale thang, and if you’re intending to use diesels as I suspect with your project, that should prove a little less daunting than the prospect of outside framed/inside framed, flexichas, shoe-horned horns, CSB/FBI/CID et al……
I guess you get the picture, Matt
Good luck!
Jon
