Dikitriki
The bearings were closed up and soldered in to fix the wheels - the clearance is very tight! The well tank works out at 30.5mm in width.
Hmm, that seems to put the kybosh on F/S then.
Hi Adrian, very nice work. Lots of rivets mmmm bet that was nice n easy .
I look forward to your next progress report.
Rob
Just as quick with one I made myself! Although the half etched dimples helped as well.Takes just a few minutes with a GW Models riveting tool!
This weeks job will be to finish off the right hand pair!!
So all fitted in place, note the orientation of the angle pieces and the rivets on the inside.
Dare you.....You never know I may even manage to get it finished before the end of the year!!
There was also a small hand rail to be added above the lefthand W iron. These were apparently fitted on the LMS version but not the BR version so there are no markings on the etchings for a drilling guide. There are a couple of rivets close by and so I pop-marked just to the inside of these to drill the holes so that the rivets represent the clamping bolts for the handrail. I suspect for the BR version these half etched rivets should not be punched through.quote
That's where I went wrong then, I was reading the instructions. There was nothing in there about drilling holes and I was just merrily punching half etched holes through as rivets. It wasn't a problem and soon sorted.That is partly true for the BR version - the outer one is a rivet and the inner one should not be pushed through - but in the context of the LMS version these are not rivets - they are actually the marker holes etched in the rear of the solebar for drilling out the handrail fixing holes which you say we do not provide - these are clearly shown on the assembly drawings.
