As mentioned previously - next up are the springs.
These are a pre-rolled set of phospher-bronze etched leaves. These are squeezed into the square pocket at the top of the axlebox. This being the first trial run.
For a first fit they seemed a little flat compared to the prototype photos so they were removed and a little more bending was required. A tin of humbrol proved to be about the right size but with the etched hole in the centre it required a little care to bend the leaf to a curve rather than a V shape around the centre hole.
Note they are a very tight fit on the pocket, I ended up slotting in the top two and then the bottom two and finally trying to push the 5th leaf in to the middle of the leaves. Be careful cleaning out the pocket to make it square. Being a bit ham-fisted and forcing it too much can result in structural failure!
Still threading the leaves on to the brass rod I could solder it back together again.
This is where I start deviating from the instructions slightly. As indicated in Christian's photo build the instructions say fit the brass rod in the spring hangers and then when fitting the spring to the W iron carefully slide the top leaf first one way and then the other to slide it under the rod in the spring hanger. Well it was tricky enough to fit the top leaf in the first place never mind sliding it one way or the other. So I took a "leaf" out of Christian's build and fitted the axleboxes to the W-irons before fitting the rod into the spring hanger.
This is where I deviated even further from the instructions, which suggest once fitted to the W-iron then the end of the top leaf needs to be rolled around the rod in the spring hanger. Trying to get a lever under the top leaf to roll it round the rod was too much for my fat fingers. So my route has been to roll the top leaf loop on the spring out of the wagon. Just using a brass rod it was a lot easier to form the hoop. Once done I could fit the spring to the W-iron and then thread the rod through the hanger and spring to hold it in position.
I also haven't soldered in the brass bearing bushes either. The kit includes several spacing washers because with the centre well there is no allowable sideslip in the wheelset. Rather than pad out with washers I'm going to solder them in position once the centre well is fitted.
Also note in the instructions there is a keeper plate to be soldered across the bottom of the W-iron. I have deliberately left this off for the moment. Part of a cunning plan which I shall have to see if it works, because the observant may have noticed that the rod for the spring hangers has not been soldered in. At the moment if I remove the pins then I can drop the springs and wheelset out of the wagon - the cunning plan is that this might make it easier for painting later on - hence no keeper plate for the moment.
So this is the current status.
Next instalment starts looking at the centre well.
