Isaac Dixon
I've taken about 2.5mm off each side of the tanks. What do you reckon?
View attachment 231934View attachment 231935View attachment 231936
I'm not going to round the top edges over, as the sister locomotive sports a squared off tank.
The revised width looks good. My reading of the Nantmawr drawing is that it shows a large radius curved top on the tank. The handrails are mounted near the edge of the curved top. The photograph used by AR Bennett when producing his drawing may not have shown the tank top clearly so it too could have had a segmental arched top to the tank. Curved steel needs less support than flat and it would look a bit more elegant than a Neilson or Barclay box tank.
spikey faz
I'm 50/50 on the shape of the tank. Sister locomotive 'Liverpool' sports a very squared off tank, but I agree that 'Nantmawr' has a slightly curved edge to the top. The Plastikard mock-ups will continue!
I do note that the drawing of 'Isaac Dixon' has a vertical row of rivets towards the front of the tank. I wonder if this was to do with some sort of internal reinforcement that was deemed necessary due to the square/box-like construction of the tank?
The drawing on which you have based the loco shows a tank with rivets right at the top of the side so presumably flat top, but the height of tank over boiler looks smaller than your mock-up.
Is the consensus from the above discussion that the producer of the drawings did not capture the true shape / proportions of the tank?
Boulton’s creations / adaptations were in the main one-offs.
spikey faz
The drawing is based on a photo which sadly I've not been able to track down. So yes, it's quite likely the producer of said drawing may have not got it quite right.
There's some sort of pipe that seems to run along the top of the tank which may be also obscuring a rounded top.
I was thinking the Nantmawr drawing shows something more like this-
The round corner looks a bit modern, although maybe I am just thinking of Manning Wardle with their similar shaped tanks which started with sharp arris between top and sides, then later the designed was modernised to rolled top into sides.
spikey faz
This is one of the great things about being able to tap into the minds of Western Thunderers: A different perspective! :cool: That looks far better than my interpretation. I shall mock something similar up and see how it looks. Thank you @Overseer :thumbs:
On the other hand - if you were Isaac Watt Boulton would you want your men to spend extra time creating a tank with a hint of finesse when a basic square tank would suffice?
Edit: On the other hand, a classic Boulton engine was a Bitsa - so any suitable tank (from an even earlier engine) might be re-purposed.
Boulton is known to have been happy to have his bookkeeper spend hours lining out locos in ornate schemes so running a thin iron sheet through some rollers would not have been a problem. Not actually relevant in this case as Isaac Dixon (and Nantmawr) were built by Hughes & Co. Boulton bought Isaac Dixon secondhand and hired it out.
Happy to stand corrected, Fraser - the engine seems to lack the inherent elegance of other Hughes locos so I assumed it had been got at by Boulton.
spikey faz
I think I may well stick with plan A. The tank depicted on sister loco 'Liverpool' has very much square proportions. Whilst I agree the curved version as per @Overseer has far better aesthetic properties, I have always (rightly or wrongly) pictured this locomotive in my mind with a squared off tank.
But..... I do have a second set of the same size driving wheels, which could end up in a model of Nantmawr! :eek:
spikey faz
I've spent the last few days applying rivets with varying degrees of success. They do seem to like wandering off course when my back is turned!
20250124_154502.jpg20250124_165244.jpg20250124_165329.jpg20250124_165538.jpg20250124_171347.jpg20250125_154428.jpg
I've lobbed everything together to just get a feel for how it's going (yes, I know the coupling rods are missing and con-rods not aligned:D).
I'm just hoping a coat of paint will hide all of my mistakes! :))
spikey faz
I think it looks fabulous
Very kind of you John. I think if you could see it close up and personal, you might have a bit of laugh about some of my dubious construction methods. I wonder if in a previous life I could have been working at Boulton's Sidings! :))
I've still got a lot to do - especially get it running! The weather looks a bit rubbish tomorrow, so might be a good time to stay indoors and progress the build.
