Isaac Dixon
spikey faz
I've been researching! :eek: I think I've got my head around how Stephensons inside valve-gear works. In any case I'm only going to try and model the bits that can be easily seen. As I have only the one sketch of Isaac Dixon to go from plus the rather hazy photo of the sister engine, I'm having (as usual) to improvise.
I firstly need to establish the position for the lifting arm. Hmm. The drill bit in the photos below indicate my best guesses.
Pete McFarlane
New Member
I've encountered some problems with the wheels. One of them has become a bit loose on its axle. Another has developed an alarming wobble, and on closer inspection I can that the centre hub has split. Not sure why, but I'm not sure how to proceed now.
The solution to the Gibson wheels shifting is to pin them in place - drill a 0.5MM hole through the boss into the steel axle, and superglue a length of wire into it (then trim when the glue is set). That stops them from moving.
Nice to see a model of one of Boulton's engines. I'm always amused by some of the imaginary Steam Punk machines that people dream up, as they always seem fairly tame compred with the contraptions that came out of Boulton's sidings.
spikey faz
Hi Pete.
I'm hoping that the replacement wheels I've got will be better. I think I may have rushed the preparation on the first set, hence the problems I encountered. I can use the old set to line things up without worrying too much about them wobbling or slipping. Then use the replacement set for final assembly. Or at least that's the plan!
spikey faz
I've made a start on the inside valve-gear. I suspect that assembling wristwatch mechanisms would be easier ;) , but I'm determined to get something installed. I am vaguely looking at making it work as well! If all else fails at least it'll look ok as a static piece.
spikey faz
Made a start on the buffer beams. So, half an hour of cutting and riveting has got me thus far.
In the meantime I found that the recently installed reversing-gear cross-shaft clouted the underside of the boiler. So the shaft had to be repositioned. I'm not convinced I have the skills or eyesight to make the inside valve-gear work now.
spikey faz
I've since found a plan for the very similar looking Hughes & Co locomotive 'Nantmawr' in the Oakwood Press book 'Boultons Sidings including Contractors Locomotives'. This appears to not have the frame cutouts, thus potentially negating the modelling of inside valve-gear. But, I am where I am, so I'll plod on and see what happens. :)
