Wednesday club night, with some help from my friends I took the layout down and loaded into the car to take it home for painting.
I normally transport it in my car which is a Volvo XC60 but we also have a Toyota Rav4 and in theory it should go in this as well. so we took the opportunity to try is and the good news is that it does with room for the stock etc.
The main baseboard was then set up in the garage and all the wooden walls and other structures were removed and put into storage. At this point I did feel like I was going in reverse.
Before I could start blasting I needed to remove the temporary wiring for the cranes and lights. This was held to the columns with Blue tack. I have now soldered some tubes up the back of the columns for the wiring.
I also masked up the running rail for the cranes to protect it from blasting and painting.
So it was now time to have a go at blasting. The original plan was to set the board up in the garden in a Gazebo but I thought this would mean bringing the layout in and out several times which would risk damaging it. So plan B, cover everything else in the garage with dust sheets and see how we get on.
With everything wrapped up I put the compressor just outside the door in the hope it will help to keep it cool, and I made a start blasting.
It was very warm today and I am still working out the best way to do it, but I have managed to blast three bays from the end, up to the side door opening.
I am managing to collect and reused some of the Ali Oxide but still getting through it.
When I did the trial I used some safety glasses over mine, but the dust still got around my face, the full face visor works a lot better.
I am hoping now to get the blasting finished next weekend, this will be a week ahead of where I thought I would be.
In parallel I have also been designing a new control panel. Up to the open day at the club the controls the wiring has been a bit of a lash up with the crane controllers on adapted plastic boxes and the power units on a chair along with the door control and the multi gauge test track selector switch.
The new design has all the units in one panel. This includes the six controllers for the two cranes, the power supply for the cranes, the power supply for the track, a three position switch for the test track for changing polarities and isolation, the controller for the doors along with a selector switch and a emergency stop button for the crane power supply.
This will also speed up the time it takes to set the layout up at exhibitions. I just need to draw the parts up for cutting now.
Andy
