In post #124 noted that the CCE dept had moved on and the formation had been returned to the PW dept., well the truth behind the statement is not that simple. The baseboards for Hartley Hills have been built on "modern" traditional lines with 6mm ply top on 6" deep sides / ends and diagonals. Sides and ends have been built on the "Barry Norman" approach. All of this can be seen in an early photograph where the sides / ends / diagonals were drawn, in red, on the top surface of the baseboard.
All seemed tickety-boo when the boards were delivered in Autumn 2011... by Christmas the top surface had sunk between the cross-members, how much depended upon the distance between the cross-members. Suffice to say that the biggest drops occured close to the toe of switches - not a good recipe for smooth and predictable operation of turnouts. Given the time spent in setting out the formations and in laying the timbers there was a vested interest in not starting again and so the existing baseboard was re-inforced by ply inserts added underneath the top surface. By selective use of the grain and curve of the new panels the extra material was affixed to the original board so as to "level" the game.... and consume a fair number of screw to produce a composite structure.
The formation is reasonably flat and fairly rigid so PW work has re-started without worry that the ups and downs might reappear.
The Up Goods line on board no.2 has been laid and the curve looks very attractive. Next step is to complete the Up Loop to Up Main turnout and then the section towards the Up Main... whilst commencing CCE tasks on board no.1 and preliminary PW work for the goods line extension.
Sorry this is in Black and White.... video practice is continuing. So far a LNWR eight-coupled tender engine has done s bit of road rolling (well that is my excuse - the prototype would often run goods services on new lines, to settle the formation, before starting passenger services), maybe a Jubilee ought to make a trip given that this is a Jubilee year. I keep hearing pleas for a Brush Type 4 to take the road, need more power for that than is possible with a 30 year old Hornby controller.
regards, Graham
