While fiddling and placing the buildings I realised that I'd need to slim down my model of New London Bridge House to fit everything in - space so easily and quickly gets used up. Such is the need for compression and simplification.
Consequently I've cut a two inch section out (one inch either side of the centre line to preserve the waisted look). It does mean that it's much more slender (perhaps too much so) although a little tubby as the waist is thicker. I glued the two halves back together which surprisingly went together easily and accurately despite the removed two inches - very relieved. To counter the slender look I also took off the top two floors to help preserve the overall height/width relationship.
One side of the tower sits on a low block and the other side has a glass entrance reception beneath with a walkway between. The walkway is now much narrower but at least I should be able to fit in the road behind that leads to the bus and taxi stands.
