Ah, thank ye so 'm deario, if only it were true ?! Painfully all too aware of the wreckage trail in my wake, I must surely be getting the spells mixed up?
Bringing the tale up to date, and while evidently wearing the wrong hat, I had to have a rummage for some suitable material for a latch rod, preferably round with a lumpy bit on one end, and found this slightly odd version of an old coach bolt:
It proved to be just the right length, and after filing down there was just enough meat left on the head to drill through for a scale size pivot bolt.
A silly mistake was to follow, but before that was discovered:
Still to finish and tidy each end, it was checked for fit.
I was pleased find that it swung quite nicely. A niggling minor detail is that the head should have been larger, with the squared top laying flush with the slot in the handle body when the lever is set in each locked position.
The error referred to was still to come...
Careful examination of drawings, photographs and even peering at the real thing, (with the weakened lever firmly wired and clamped there was no opportunity to try it out at the NRM) have failed to reveal the precise means by which the rod moves vertically in linear motion, while the top end has to follow the radial action of the handle? I therefore opted for a subtle and buried pin between the rod and latch:
I chose brass rod for two reasons: Firstly, such a fine and enclosed pin would be less effected by rust, and it would be softer and easier to hammer down flush on the bearing surfaces on either side of the latch.
All sweet it seemed, until I tried to slide the assembly into position !!
Ahhhhhhh !
The pivot head might be prototypically too small, but it was still too big to pass through either guide from below.
Rather than sitting back, having a fag and cuppa while contemplating a sensible redesign solution, I allowed the Neanderthal genes to have a go instead!
"Derrr..., it
must go in that way..."
Amazingly, and I'll never be sure how, it went in!
I then realised that there was no way to insert the essential spring without pulling it halfway back out again.
(It gets worse):
While attempting that, I discovered that the joint between the lovely stainless steel handle and the plywood lever was not so child (or idiot?) proof after all !
Four new brass "rivets" and a slightly mangled "Biro" spring later...!
Sadly, it is now working smoothly and beautifully, but not quite so prettily. My ancient ancestors may carry on laughing at me for a little while longer - at least until I get round to replacing the brass pin and bent spring with a simple, slender and lets face it, much more sensible grub screw anyway!
I still need to find a matching M3 nut and bolt for the main handle pivot, but in the meantime, a splash of my "oily steel" mix at least gives the impression of advancement.
With my lumbar problem receding, and with it a reliance on paracetamol, is it nearly, or really safe for me to start picking up hard or sharp things in the workshop again... ??
Pete.
