3 LINK
Chapeau. Congratulations, Pete, that's incredible.
Ditto , amazing.....
Martyn.
Well, I didn't quite "go" as it turned out. I spent the next three or four hours worrying myself silly about it before finally plucking up the courage!
These two images show what I was after:
View attachment 139844 View attachment 139845
As you can see, the original Beyer Peacock handwheels where rather elegant and slender affairs, with three slim rounded spokes.
Something a bit like this....
It is said that "There is a first time for everything", though if nobody minds, I would rather it would be the last?
Nevertheless, by the wee small hours there was one utterly exhausted, but at the same time very happy chappie that finally collapsed into his bed!
Yesterday afternoon seems like an age ago, but this is how it started...
After a good old rummage around I was very relieved to discover that I had two very short offcuts of 3mm brass rod, just enough to cut the three spokes from.
Accurately marking out, centering and then drilling for them into the 10mm hub was a bit hair raising for me! All the time I was quite convinced that I would have to spend ages bending, twisting and bashing the spokes into something resembling alignment?! I also hate starting off a drill on a curve and always tend to assume that the bit will suddenly go skidding away off course, or even possibly snap in the process?
To my absolute amazement, each one ended up pretty much in the right place, and at the right fippin' angle too! I will never be quite sure how I managed that?!
Now here is another part that was scaring me even more:
To be scale, the rim was to be rolled from 4mm rod in some of that wretched CZ121 brass.
My first thoughts had been to form and solder the full circle, then carefully drill 3mm holes right through from the outside, hoping to perfectly align them with similar in the hub and push the spokes through and home?
No b****y way!
3mm holes in a 4mm round rod? Got to be kidding, right?! Knowing my unerring ability to drill wonky at almost every attempt, it could only end in tears! I feared that the only option was an utterly crazy one?!
An 8mm wide strip of masking tape was cut and rolled round each spoke to ensure accuracy, then flats were filed on the ends and on both sides of the spokes:
View attachment 139854 View attachment 139855
With that task done, it was time to start the annealing job!
Thanks again Tim Watson for the vital tip! I've not done it before, so it would prove to be interesting?!
I found an odd, rusty bit of scrap steel that just happened to be fractionally less than the required inside diameter of the ring, thus allowing for spring back during bending.
Jammy or what?!
When applied, the little gas torch just about managed to briefly bring small patches of the brass to a dull, pinkish red. After quenching, the previously hard stuff was like butter, and came round nice and easy, or least for just a few moments before it stiffened up again though!
Slowly, slowly, the jolly dance across the workshop floor bore fruit:
I know that is "old hat" for the seasoned and highly respected engineers amongst us, but it was proving to be an enormously enjoyable, though quite tiring adventure for a creaky, prematurely ageing novice!
Now for the really crazy bit:
Chopping it all up into pieces...
View attachment 139857 View attachment 139858
To my delight, I found that zipping out the little slots with a needle file was considerably aided by the annealing process too!
The order was heat, quench and bend a section, (three times for each short length) cut, shape, fit and then repeat for the following two sections.
Buoyed on by a fairly snug fit with the first section. The second seemed to fit even better!
With two on, there was still a bit of leeway for jiggling, but the last section required rather more of a fuss to finally fit it all round!
I had not yet separated the wheel from the rod when this shot was taken, as it was giving me something to grip when burnishing it up!
Sorry, I'm not thinking of taking up jewellery as a new hobby. I doubt if I, or more particularly Mrs., I, could cope. She thought that whittled plastic was bad enough?!
Pete.
This is looking mighty impressive now. I keep going through the images trying to watch back some of the work done to achieve the results and just sit in awe of the time and work spend in hand filing and cutting metal to make such beautiful parts. I really can't wait to come open and close the door and listen to the little clink or clunk it makes in person!
Fantastic work
I've had this comical thought in my head of the ruckus that will take place in the Insole household when it comes to who's turn it is once it's finished and the Grand-kids out in the garden saying one to the other " Oh just let 'em get on with it they'll soon get bored " !
Col.
