Beginners OO 1950's Banff
40057
Well, at long last, cottage #2 completed, excepting guttering, downpipes and chimney pots.
Thanks again to @40057 for pointing out several details that I had ignored or overlooked, especially the general layout of the rear of the cottage. I'm so happy with the result that the next task will be re-working the rear of cottage #1. I don't have any photos of the back of this particular cottage, so I have borrowed the layout from another.
‘Cottage 2’ looks great.
On the photographs of the cottages, rust staining on the slates below the cast-iron roof lights due to salt spray is very noticeable.
aardvark
The renovations to cottage #1 are complete (-ish). I can't believe it's taken a month, but there it is.
The front hasn't changed, but the back has, from this ...
... to this ...
... which is considerably more representative.
Here's both the cottages in place ...
One day, there will be a road at the front, covering up the bare plywood.
And here are the cottages from the back, which no one will ever see ...
Cottage #3 will be next inline, literally: an interesting variant that has been called a half-and-half.
aardvark
Progress on cottage #3 is progressing, albeit at a rate slower than is normal, even for me. Apart from the typical Christmas/New Year interruptions, I recently had the first cataract operation. The ophthalmologist promised I'd be about "like normal" the next day, but he has been somewhat economic with the truth. A few days out and my vision has improved enough to get back to some modelling, and here we see the decorations around the front doors and windows nearing completion.
The T-shaped piece in the middle is destined to be the sill for the right-hand window.
aardvark
I thought I should post a progress photo before my 2nd cataract op tomorrow, and the ensuing week or more of enforced inactivity.
Here we see the internal wall of the half-and-half cottage held vertical by a Neat block and a small magnet while the glue sets.
Still a long way to go. Besides the roof, there's two different dormers and the lean-to at the back to attend to. Not sure when I'll be back, as my bionic eye has a focal distance that's a bit long for modelling, and to date I've been relying on my organic eye for close up work.
aka Toolmakers' blocks, 3-2-1 blocks, 2-3-4 blocks etc. The RS ones look nicer than the Amazon ones. And cost roughly three times as much!
Simon, apart from the pretty-pretty attribute... does RS offer any advantage / benefit over the Amazon offering?
Rgds, Graham
aardvark
Quick! Put the kettle on! We've got visitors!
@Rob R is correct - a block of steel that is flat on all surfaces and square on all angles. I coined the term Neat block, having first read about them on a blog by David Neat here: Main construction, and, well, they are neat and give neat results. Now that I see it in print, the name 1-2-3 blocks also rings a bell.
@40057 is also correct: never diluted with water.
I had mine made by a local engineering company. I have two: 20x40x80mm, which weighs in at 498gm, and 20x40x150mm (937g). More versatile than the ubiquitous Engineer's square. I'd say I prefer my version (without holes) as the flat surfaces are useful, and, I expect, much easier to stick magnets on.
Here's another picture of them in action.
Ditto, just bought some too.
Question... What bolt or thread fits in the holes?
From the Amazon link it says "5 holes are trapped 3/8-16 threads" so assuming it's a typing error and they mean tapped then they'll be 3/8" by 16tpi - so probably 3/8" UNC - or maybe 3/8" Whit.
Interesting choice of thread there, the only time that I have used UHC is for studs fitted into the aluminium castings of Land Rover Series:II and Series III gearboxes - real dinosaur stuff.
Rgds, Graham
Well, we use RS at work, and I have a personal account, delivery is free over £30, so they’re convenient and generally offer very good service. You’d be pretty sure that what you see is what you get, and you’d also have confidence that you could return anything that didn’t come up to scratch.
But Madame has an Amazon account, delivery is prompt and free on Prime, and on the odd times we’ve needed to complain, the customer service has been excellent.
I’m assuming both offerings are square and of the dimensions advertised within a reasonable tolerance.
There is a pleasure in using a good tool, as against an adequate tool. For a steel brick, I’m not convinced that’s worth thirty quid!
I guess you pays your money!
atb
