4mm Llanfair ....
LarryG
I think your latest 'kit bashing' exercise has produced a more convincing, WC for a backwater like Llanfair Road.
This 'slow modeling' is giving my ideas time to develop. I decided the Ladies toilet can stay where it is at the back of the tea room and the toilet block will be just for gentlemen with two cubicles and a urinol. Taking up less space, it can be set back a bit from the main building...
LarryG
Ready for the sprayshop as are all the other components parts that go on later. Chimney pegs into holes and can be painted separately...
Removable nameboard needs painting and a frame fitting. William Wroe was my wife's father, a lovely man..
Geoff
Yet another lovely building Larry, naming the coal merchant after you father-in-law is a nice touch.
I'm looking forward to seeing all your buildings in situ on Llanfair Road, perhaps the current mild weather will tempt you out to your shed for a planning exercise?
All the best for Christmas and the New Year,
Geoff
LarryG
All the best for Christmas and The New Year Geoff. All the buildings know where they're going because it was well-rehearsed in '00'. Mild weather or not, I do nothing in the shed from November to March. I tend to run a regimented regime that ensures I eat well and layouts are built and ripped up at the appropriate times.....:p:p:p
Larry
LarryG
Busy with "Christmas", but I finished the roof-mounted nameboard if nothing else....
The nameboard was sprayed with car paint and left to harden before brushing on PPC White enamel and wiping off the surplus. The surround was glued on afterwards with Evostick Impact the picked out with with PPC GWR Light Stone...
LarryG
I found time to weather the whole building this afternoon. White mortar was tested on a small section, but it bleached the bricks .... as usual. I never learn! So it was quickly followed by using Precision 'Dirty Black' diluted to taste with turps substitute. I can't go any further tonight until it has been matt varnished
LarryG
Extra bricks picked out wit PPC Light Brick red and GWR Dark Stone, although they dont show up clearly on the photos.....
Door handle required. Must remember to order some from Intentio...
Now it is finished, I realise it is the ideal building (minus chimney & roof board) for use as a fully enclosed Gents toilet same as at Carrog. So that's another job for the New Year.
LarryG
Intentio coal bunker now, the perfect xmas filler when spare time is scarce haha. One plank gone missing at this end.....
Bags of distressing called for with shovel marks made by constant stabbing with a screwdriver. Note the base of one vertical support post is rotten at the base. The horizontal score was made by one of the coal lorries (!).....
LarryG
I inadvertently posted this on Geoffs Bleddfa Road earlier. I'm sober now .... :rolleyes:
The toilet block or hut as it is now seeing as a further 40mm was removed from the length. Windows apertures have been bricked up to support higher frames as per suggestions from Farmer Rowland@Northstar, an in-joke between him and me. Metric size size bricks ha ha....
I admit to having been confused…
I do like the “bricked up” effect, I guess you’ll vary the colour of the newer bricks?
on the cubicle topic, my late pal Ken Stansfield moulded toilet pans from Milliput for his Swanage station building. I guess the 3D printer would be the obvious means of so doing if one were so inclined, but I have so far resisted the temptation!
oldravendale
Hasn't our good friend Peter Insole carved these from the solid for his own (and our) delectation already? Can't find the post now but it was a while ago.
Brian
Paul Tomlinson
Brian
Brian, here's Peter's post. A wonderful piece of work altogether.
Andy Duncan offers us (7mm modellers) a short cut with his whitemetal castings :
LarryG
Neat as the castings are, would they be seen behind frosted glass.....? I built the two lav doors because they would be seen through the open entrance door. I'm painting the building at the moment, but because its all about space and appearance, there are several ideas on my mind as regards a 'Gents'.
