4mm Llanfair ....
LarryG
Chimney stacks went on last night, a job that demands lots of viewing from all sides to ensure vertical-ness. Beware the glue dries out thereby pulling the wood down and you end up with a cock-eyed stack! Steel rule and something heavy kept this stack in place while the PVA set...
The book at the back acted as something truly vertical...
A screwdriver was wedged in the chimney hole and a strip of cardboard wedged under the base while the glue set on this beggar.....
This stack gave me some problems, as it had to be extended under the gutter after considering the interior and position of staircase....
'Lead Flashing' is masking tape.....
LarryG
Finished and ready to be stored away, so that's another job out of the way. 7mm scale is such a pleasing scale.....Well at my age haha....
I said finished, but the gents urinal is due to be replaced by a separate Gents & Ladies toilet building more commodious than those at Carrog. When the ladies toilets are removed from within the nearer building, the tearoom will be enlarged to a Cafe for postwar tourist traffic...
Entrance side of the building. Gluing the tall chimney stack to card slates wasn't strong enough, so they were removed so that I was gluing wood to wood....
Detail shot. On the lookout for brass doornobs.....
Cast whitemetal chimney pots are from S&D Models....
Geoff
Those chimney stacks and pots certainly set the building off Larry, such tremendous modelling. I have also been searching for some door knobs and the only ones I have come across are these........https://www.intentio.shop/index.php?route=product/product&path=18_74&product_id=260
Geoff
Geoff
Geoff, have you looked at Brass Pins as Knobs?
Geoff
I've only come across the bog standard plated ones in my wife's sewing box Phil, and none were really suitable. So being a glutton for punishment I filed some handrail knobs down and filled the holes with brass wire. They aren't too bad from a distance but I'm sure Larry will want something better for his masterpiece, as do I.
Geoff
LarryG
I was going to use Peco track pins but haven't any. The Intentio door knobs certainly look the part. I have some kits on order from Intentio at the moment and would have added a couple to the order had I known about them.
mswjr
I am into model engineering as well as oo gauge, for doorknobs in oo an o gauge, i have used brass snap head rivets, they will come in 1/32. 3/64. and 1/16, this is the pin size so the head will be bigger. A company called EKP will sell you a 10 pack, I can give you the head size of rivets that i have. They will look good.
LarryG
It being doubtful I will ever build another 4mm coach, I have been tipping bogie castings out of drawers into a box ready for recycling. Only a few drawers are needed for my own modelling, so I brought my very first set in from the garage, sanded them down and sprayed them cream for on the wall in my room. They were made in Denmark in the early 1970's long before manufacturing went elsewhere. The drawers are large enough to get a hand in to pick things out, unlike later purchases from China where I had to use tweezers. The redundant drawer Unit on the desk...
The 1970's drawer carcase sprayed cream ad wall mounted for screws and 7mm parts....
On the modelling front, the gents lavatories were carefully removed and the wall tidied up and repainted. Blemishes have been covered by Western Region poster boards although much of the wall wont be seen once the new block of ladies & gents toilets is built....
Geoff
That is so sad to read Larry, but I live in hope that you will perhaps build one in 7mm scale.
I was reading back through your account of building your station building and how much you enjoyed 'kitbashing' . Our generation were brought up on cutting and carving the old Tri-ang Princess and B12 bodies if we wanted something different. The Railway Modeller was full of many clever conversions at one time. I remember one talented chap who made a stud of ex LMS / L&Y locos from styrene sheet and mounted them on Tri-ang chassis, they went down very well with my friends and myself when they appeared in RM. ;);)
Geoff.
LarryG
Geoff.
Wow, that's going back a few years Geoff. They were all built in the early 1960's when I was on Oldham buses. As for 4mm coaches, I have no use for them and ceased trading some years ago. But yes, I do intend building a 7mm Parcels coach, hopefully a K42, but I can only find a K38 Ocean Mails.
Geoff
That article is still fresh in my mind Larry :)
Hope you come across a K42 soon, I'll keep my eyes open.
I believe you were responsible for the models in the showcase at 31A Rhos Road, is that correct or did George and Jumbo build them?
Geoff
LarryG
George Mellor asked me to paint his showcase models when I moved to North Wales. He introduced me to low melt solder and flux and I then built his kits as well. One weird job I did was painting panelling on brass patterns for I.O.M coaches....... His office stank so much of cellulose paint that he and his wife buggered off home! :p
