Prototype Tim Mills' Photos
oldravendale
Thank you, Dave @Yorkshire Dave for coming up with the actual location of the Standard 5 and West Country photos. The info about those EMUs is so very helpful too. Also for your thoughts about the identity of the Bulleid Pacific but I'm going for 34009 for which I thank Barry @Barry37 and James @James Fibbens.
Rebuilt Merchant Navy 35012 United States Lines at Byfleet Junction from the West Weybridge direction in the 1960s so probably July 1965. There’s a blue and grey GUV at the front of the train which is a set of Pullman coaches so probably the Bournemouth Belle. There’s probably a blue and grey GUV at the rear of the train too. 35012 was resident at Weymouth Radipole from August/September 1964 when it moved to Nine Elms in March/April 1967. It was withdrawn in the same month (SLS) and went to Cashmore’s, Newport where it was scrapped in October 1967. (BR Database).
img573  TM25R.  35012.  West Weybridge.  In the 1960s.  copyright FINAL Resized.jpg
Standard Class 5 4-6-0 73018 at Berrylands in the 1960s so probably in July 1965. Home for the loco was Weymouth Radipole from September/October 1958 but it moved to Guildford in March/April 1967 where it was withdrawn at the end of Southern steam in July 1967. (SLS). It was scrapped at Cashmore’s, Newport in January 1968. (BR Database)
img574  TM26.  73018.  Berrylands.  In the 1960s.  copyright FINAL.  ENHANCED CONTRAST & BLUE ...jpg
Original West Country 34038 Lynton in the 1960s. The first photo, img575, is confirmed as being at Feltham (obviously a good freight engine (!) as there were plenty of alternatives still around at the time and everyone knows they were a mixed traffic class). It’s reasonable to assume that the next two, img789 & 791 were photographed in the same location on the same day. The loco was allocated to Eastleigh in October/November 1961 and Nine Elms in December 1964/January 1965 where it was withdrawn in June 1966. (SLS). It was scrapped at Cashmore’s, Newport in September the same year. (BR Database).
img791.  TM.  34038.  Poss Feltham.  Date Not Known.  copyright FINAL JPEG Resized.jpg
img789.  TM.  34038.  Poss Feltham.  Date Not Known.  copyright FINAL JPEG Resized.jpg
Brian
Barry37
Thank you, Dave @Yorkshire Dave for coming up with the actual location of the Standard 5 and West Country photos. The info about those EMUs is so very helpful too. Also for your thoughts about the identity of the Bulleid Pacific but I'm going for 34007 for which I thank Barry @Barry37 and James @James Fibbens.
Brian
You mean "... going for 34009", not 34007 (which wasn't rebuilt), surely?
oldravendale
Absolutely correct, Barry @Barry37 . Fat finger (and failing to check my work) syndrome! I'll now edit. In fact I'd changed the brief description of the photo in my files correctly!
40057
The GUV is a BG.
GUVs were generally (always?) all-over blue. (Edit to add: blue as opposed to blue and grey. Red or maroon when those liveries were current).
Martin
More than likely as the headcode is Waterloo and Nine Elms and Brockenhurst and Bournemouth West via Sway.
This is also a Bournemouth train.
The headcode displayed didn't exist for trains starting at Feltham Yard. For trains starting at Feltham Yard and for the discs as seen: right hand disc only - Willesden and Feltham Yard via Gunnersbury; left hand disc only - Willesden and Feltham Yard via Kew East Junction. Could be one of them wasn't removed.
Another possibility is it could be part way through a journey which started at Reading as this headcode was either:
Brent or Neasden or Willesden to Reading via Kew East Junction.
Temple Mills or Victoria Docks to Reading via Victoria Park and Kew East Junction.
For this journey it could have been - Reading, Wokingham, Ascot, Staines, Feltham, Kew East Junction, Acton Wells Junction which would either send the train to Willesden and North London Line for Temple Mills or to Brent or Neasden.
It can't really be anything else than the 'Belle by that date - any other Pullman special would be unlikely to have had the additional BG at the front and a blue grey one was common by that date, but photographic evidence shows every other colour of BG you can imagine: chocolate and cream, green, maroon, etc.
Here's a green one (because I've heard it said that no such thing existed):
oldravendale
Thanks for your comment, Martin @40057 but I'm pretty sure I saw some maroon BGs and there were evidentially some green ones. Thanks to Adam @AJC for providing evidence and Dave @Yorkshire Dave for additional comments. Thanks also to you both for the comments about the Bournemouth Belle and to Dave for confirming the head code of that Standard 5. As far as the photos of 34038 are concerned I'm comfortable that they are at Feltham - D3459 which features in one of the photos was at Feltham from November/December 1962 to June/July 1970 (BR Database). It fits with your advice about the possible route if it had stopped at Feltham for servicing and water.
Standard Class 3 2-6-2T 82023 at Vauxhall and probably on empty stock in the 1960s. The loco was allocated to Eastleigh in September 1962 but moved almost immediately to Nine Elms in October/November the same year. (SLS). Doubtless its presence at Vauxhall was at the time of the Nine Elms allocation although it’s typically for the time not carrying a shed plate. The loco was withdrawn from Nine Elms at the end of September/beginning of October 1966 and went to Cashmore’s, Newport where it was broken up in March 1967. (BR Database).
img576A - TM28.  82023.  Vauxhall.  In the 1960s.  copyright FINAL - Lighter Printing Copy (2).jpg
Standard Class 5 4-6-0 73022 at Berrylands in the 1960s. This was allocated to Guildford in June 1965 and Nine Elms in June 1966 before withdrawal in April 1967. (SLS) It went, along with many other surviving SR locos, to Cashmore’s, Newport where it was scrapped in September 1967.
img576C - TM29.  73022.  Berrylands.  In the 1960s.  copyright FINAL ENHANCED CONTRAST AND BLU...jpg
Original West Country 34007 Wadebridge at Waterloo in the 1960s. It was a Nine Elms loco for many years but moved to Salisbury in August/September 1964 where it was withdrawn in October 1965 (SLS) and sent to Woodham’s, Barry. See
34007 Wadebridge (SR 21C107, BR s21C107 & 34007) for details of its restoration.
img588 - TM30.  34007.  Waterloo.  In the 1960s.  copyright FINAL WITH REDUCED BRIGHTNESS Resi...jpg
Brian
readingtype
I'm intrigued by the first vehicle in 34007's train. Its end profile is that of a freight van. A four-axle GUV perhaps? But the sharp corners of the roof seem wrong. The vertical part of a step frame seems to be highlighted below solebar level.
Ben
Ben
Good spot. I wonder whether it's one of the fibreglass PMVs. Dad's modelled one and the profile and steps are suggestive:
plastic-van-gif.14212
John Palmer
That's really useful info, Arun @Arun Sharma and clarifies the details I cobbled together from the on line records. Your comments are added to the data attached to the photo.
Also (and again) to Dave @Yorkshire Dave. I believe we've been at that location previously but your correction of the description is again most welcome.
Standard Class 5 73088, previously Joyous Gard, at Berrylands in July 1965. Note the two EMUs on the left of frame, one with a yellow panel and the other still in plain green. The third coach in the train is in blue and grey and all these factors are indicative of the date of the photo.
73088 was allocated to Nine Elms in September 1958, moving to Guildford in October 1965 and being withdrawn in September/October 1966. (SLS). It was scrapped at Cashmore’s, Newport in June 1967. (BR Database).
This is at Berrylands in the 1960s so more than likely on the same date as the photo above. I’ve tried to identify the loco from the photo but it appears to be 34069 which makes it Battle of Britain Hawkinge but I think this is a West Country judging by the badge above the nameplate and 34069 was never rebuilt. Furthermore Hawkinge was withdrawn in November 1963 so it’s rather ruled out and instead we’ll have to call this an unknown rebuilt West Country.
Brian
Re the questioned rebuilt West Country, I also think this may be 34009 Lyme Regis, as I think I see in the crest two wavy blue lines on a white ground beneath something gold on a red ground in the upper part . This would be consistent with the crest carried by Lyme Regis.
David B
A minor point, but I wonder whether the dates of the photos of 35012 at Byfleet and 73018 at Berrylands are a tad early. I haven’t managed to find any photos of blue and grey Mk1 BGs on the Bournemouth Belle before September 1966, and the late Chris Foren noted on RMWeb in Sept 2016 that “The Railway Observer, often good for carriage minutiae, records in 1966 the transfers to the Southern Region of the following BGs [though when they were actually transferred is not recorded] and their being painted green: 80561, 80714, 80916, 80926, 81153, 81273, 81292, 81345, 81510 and 81542. It also records in the October 1966 issue that S80645 and S80875 had received blue and grey livery so it is clear that not all the SR's inherited BGs carried green.” The front BG in Tim’s photo looks very clean, so I would suggest that the photo was taken in late summer/early autumn 1966 rather than July 1965. Likewise 73018 is carrying the non standard replacement front numberplate which it had in 1967, but there is a David Canning photo of it at Reading West on an interregional service dated 1966 where it is carrying a standard numberplate. So maybe the Berrylands photo too should be dated to late summer/early autumn 1966.
I think I should get out more!
hrmspaul
The GUV is a BG.
Martin
Generally yes, but this Motorail one (and I am sure there were others) is blue and grey BR Non passenger carrying coaching stock BG GUV NNX NCX NEX NEX NKV NKA NJV NJX NBA NCV NAV NJV NLZ | 96153_GUV_as_NXX_Inter City Motorail @ Thornton Junction 89-08-01_m_ And later some made it into Royal Mail Red. BR Non passenger carrying coaching stock BG GUV NNX NCX NEX NEX NKV NKA NJV NJX NBA NCV NAV NJV NLZ | 93571_[ex 86571] NJX_GUV_@ Cambridge 90-05-05 _m_
Paul
Thank you for yours, Ben @readingtype and Adam @AJC for providing the likely answer. Here are two detailed pics of the area in question, one with the a straightforward lightening of the image and another with the shadows lifted. It's still very indistinct but may just help the identification.
Brian
I - and dad - reckon that's conclusive. I think there's something like a Mk 1 BG beyond in the gloom. Thank you, Brian - it's not quite the unique prototype vanwide we had earlier in the thread but that's one of ten.
hrmspaul
Brian
I'll agree that is one of the fibreglass PMVs. Good Photo and Mike King drawing in Gould, David (1992) Southern Railway passenger vans. The Oakwood Press 128p ISBN 0 85361 4288 and King, Mike (2006) An illustrated history of Southern Coaches. OPC 224p ISBN 0-86093-570-1
Paul
oldravendale
It's a while since my last post. A trip to Mexico and another to Cornwall have intervened but I'll now pick up where I left the post hanging earlier in May.
David @David B - your information is really helpful and I reckon you'll likely be correct about the date of those photos. One of Tim's few failings was that his records were quite often written up some time after the event and in fairness sometimes I've taken a guess. As for getting out more - if you can provide info of this calibre please stay in!
Then Paul @hrmspaul . As ever your information and photos are gold dust so many thanks for those references. Also for your comments giving further credence to the van as suggested by Adam @AJC and dad in the photo of 34007.
Standard Class 4 2-6-4T 80137 at Waterloo in the 1960s with what I read as a 70A Nine Elms shed plate. This was a Guildford engine in March 1963 and moved to Feltham in August/September the same year. It moved to Nine Elms in November 1964 and was withdrawn at the end of October 1965 (SLS) which I believe gives us an eleven month window for the series of photos at Waterloo. It was scrapped by Cox & Danks, Park Royal in January 1966. (BR Database).
Black 5 44882 with a 12E, Barrow shed plate, allocation confirmed by the inscription on the buffer beam believed to be on Shap in the mid 1960s. Note the banker in the far distance. The loco was allocated to Barrow in Furness in June 1961, moved to Carlisle Kingmoor in December 1966 and was withdrawn in July 1967 (SLS). It was stored at Kingmoor and seen in October 1967 (RO) and went to McWilliams, Shettleston but there is no physical scrapping date. (RO).
Probably on the same date and at the same location as the photo above (img590) is Black 5 45187 on a passenger train. This was an Edge Hill engine from May 1960, then moved to Patricroft in May 1968 where it was withdrawn later the same month. It was in store at Patricroft from June to September 1968 (WHTS) then went to Draper’s in Hulll for disposal (RO) where it arrived at Neptune Street Sidings on 8th February 1969 and was scrapped on 3rd March 1969. (WHTS). BR Database agrees with a scrapping date of March 1969.
Brian
