John57sharp
Terrific progress Jon its coming together very nicely indeed.
The architrave gives the building some gravitas too.
Nice one!
Nice one!
Jonte,
Superb work, just as we would expect, from you.
Nice one!
Looking quite magnificent!
Nigel
!Fine work, Jon. I might say buildings are right up your street...............!
Now running for cover,
Roger.
Not boring at all Jon; that’s the great thing about forums (fora?) like this. We can get these problems off our chest and just possibly someone might have an answer to help. Looking back at your thread I might have done things in a slightly different order. Get the track down and wired up first; make sure it all works and then start the weathering process. That last bit can often cause problems because of the nature of trying to dirty and clog up something that works best clean and unclogged. Keep the worst of the weathering stuff away from moving parts and rail tops is always a good start. Hopefully you have got to your track in time and it will all work as intended.Thank you, Nigel.
The task is to try and match the opulence of the platform facing side,with its flared crest and architraving, without going overboard as this side won’t be seen.
I suppose I’m just enjoying a bit of modelling before I have to roll up my sleeves and start the onerous task of cleaning the rails of the seemingly miles of track now that the good weather has arrived (whilst I prefer to work outdoors at these times, I suspect I’ll have to clean the track on the layout itself as the wires mean I can’t place the pieces on a flat surface).
With mention of track, I noticed after taking those Christmas photos that a bloom had started to appear on the sides, above where the wires had been soldered. Having since ventured into my garage workshop where the rest of the track has been overwintered, I discovered each section is annoyingly the same. Having ‘Cif-fed’ the soldered areas after soldering and washed off with soapy water, I’m pretty certain it’s not the flux that that’s the culprit (an absence of verdigris), rather I suspect it’s a reaction with the salt I used to coat the track whilst air spraying ( I hope!).
Hopefully warm soapy water will do the trick……
Also, the spring action in the points (whilst still holding the switch rails against the stocks) has become rather woolly in several, possibly due to the painting weathering process? This was identified before I had to postpone workshop working and a graphite lubricant was ordered in the hope it might remedy matters. I’m crossing my fingers that this will indeed rectify the problem i.e. the reassuring click will return.
Wish I’d stuck with Peco Setrack, but thought that using Hornby (Rivarossi - or Rivarubbishy as I prefer it) would be more in keeping with the traditional train set theme. Heigh, Ho.
Many thanks once again, Nigel, and sorry to bore you with my latest woes.
Jon
Best
Nigel
Blood, sweat and tears! Worth it though Jon. You are correct that once you see something irksome, it has to go…. I have multiple iterations that will testify to that. It’s looking good to me.
Sorry about the lack of input, major none-railway related works going on “out the back” while the weather is nice, but I have managed to do some much needed track maintenance out there as well as hacking back the enthusiastic growth that covers parts of the route,so trains soon….
I also decided to fashion some steps (with worn edges) for the little people to enter the station, although how they will achieve this is beyond me as I’ve modelled the doors closed in traditional model railway building fashion:
Nice to see a Neo-Georgian classical style railway building - far superior than the GW random stone affairs.![]()
