4mm Llanfair
LarryG
An advantage of forming landscapes from vinyl sheet is the ease of cutting chunks out of it for buildings. A lot like digging footings. The embankment wraps itself around the coaling platform. As I have said previously, this is only the start. Grass detail will be added later on...
A different approach was necessary for the water tower, so a large hole was cut and the embankment kept back with a stone wall. Chipping were laid down and will be weathered later on...
paulc
This is really starting to look the part . Great job Larry .
LarryG
More grasswork added today. Static grass was glued around the coal platform to fill gaps in the vinyl. It will more closely match the backscene when the vinyl grass is completely covered...
From this end of the layout, there doesn't seem much grass...
I'll concentrate on the station end tomorrow, which is mostly fencing and drystone walls...
LarryG
The coaling stage was removed this morning. It stuck out like a sore thumb in the distance and ruined the illusion of distance...
All the basic groundwork for scenery was completed this morning as well. The low embankment opposite the station platform is really a safety feature with the layout being wide at this point and close by the shed door. It was cut short to enable low-level photography...
Larry,
Could the coal stage not be much closer to the water tower?
Hopefully preserve the openness and space, but still have the feature, and interest it generates?
best
LarryG
Larry,
Funnily enough, it was closer to the water tower before I started on the scenery. It would only have encouraged the fireman to clean his fire and chuck the contents of the ashpan trackside... :p
LarryG
The road outside the gate is painted on. A road widening scheme is planned along with a fence on the other side of the road!
The weighbridge and coal office are against the backscene now instead of behind the bufferstops as on the previous Llanfair. Still lots to do...
LarryG
A few comparison shots from today. A hedge was painted on the backscene on the other side of the road by the gate. Static grass was completed at this end of the layout today showing how well it matches the backscene...
As before, a Hornby stone wall was but at the back of the goods yard...
Static grass around the cattle dock shows the difference in green. The raised mound on the platform has yet to be tackled
LarryG
Looking good and all happening so quickly!
Llanfair has been built so often that I don't have to think. :D
This small alteration took all day. I decided to make an end-loading platform behind the waiting rooms. A solid block of shaped wood was screwed in position and covered with stone chippings and of course edging slabs.. It will be handy for cars and agricultural equipment etc
Another view of the end-loading platform.
LarryG
Today, I set to work making the land beyond the bufferstops look as if it rises slightly. Then a stone wall was added a couple of inches in front of the fence on the backscene...
The shrubbery behind the wall is only temporary until I find some decent bushes
A match stick was sunk into a hole beside the buffer-stop and spear-fencing added. Sprayed matt black, it was glued into a blob of PVA and static grass added. This part was copied from a colour photo of Llanfyllin...
LarryG
A video of the Llanfair & Welshpool Ryl. filmed in the early 1950's shows the line was a prolific carrier of sheep, so I've 'levelled' some land then the cattle pens can be doubled in length.
Forgot to mention a third re-used turnout ~ in the same place~ failed and was replaced yesterday. With no taste for spending, a brandnew small radius that I had in stock has replaced a large radius point. All track renewals are flat bottom 'Streamline'.
