I have happy memories of those Greenfield days. Sunday morning trips to a certain model shop on Chew Valley Road spring to mind, as does the look on Norman's face when someone paid with plastic.Back in the Greenfield days, I recall you saying you would never model Delph because it was too sleepy and nothing ever happened there, so I do wonder.......
Dave.
Geoff
Larry,Norman Wisenden's was as much Greenfield as Pots 'n Pans (local hill).
My poor goods shed has been a movable feast since the early days of this layout. So I am just illustrating am option in case it helps others because a similar signalbox/goods shed situation existed at Fairford, terminus of the Witney to Fairford branch (also a Lechlade).
If I want the shed at the end of the station platform, the signalman has a view down the tracks so long as the shed doors are open. In reality, the tiny signalbox is now't more than a glorified ground frame. There are no through trains ~ one hopes, so I think it is getawayable.
Fairford terminus....
That's just Rule 55 except he's not reporting the train is complete but is waiting at the Home signal.The local instruction for Truro (even with the Mid Cornwall Resignalling) is that if a platformed train is held at a red signal, at the five minute point, the guard must contact the ‘Bobby’ to confirm the train is complete. It’s a legacy from absolute block days, which ended earlier this year. However, there are all sorts of local rules which could be applied to your layout (as Tim has rightly said).
The local instruction could simply be the guard confirms to the signaller that the train is ‘complete’ on arrival. Little things like this add to the story you are portraying with your layout
Some cosmetic hairs are needed here and there....
As far as I can remember (it's a few years now since I retired!), the configuration of the signals and block sections in that part of Cornwall meant that the Truro signaller was not able to see the tail lamp of an up train, until it had passed the box. If the timetable is sparse and there's nothing waiting at the signalbox in rear (latterly all the way back at Roskear Jct - Cambourne), then that's not such a problem. But if Roskear had something to offer forward to Truro, then the section must have been cleared and the only way that can happen on the Up at Truro, is for the guard to confirm to the signaller (as soon as the train has arrived at the platform), that the train is 'complete with tail lamp'. That then means that Truro could accept the next up train from Roskear and turn his block indicator to 'Line Clear'. That then sent an electrical release back to Roskear, enabling him to clear his Up section signal, an essential action if the next train was non-stop and needed a green at the Up Distant, in order to maintain the timetable.I don’t know if this is of use or not…
The local instruction could simply be the guard confirms to the signaller that the train is ‘complete’ on arrival. Little things like this add to the story you are portraying with your layout.
I hope this is of some use.
Best wishes,
Back to the model, populating the layout with rolling stock helped a lot. Key advantages were a more open yard, no shadow from the goods shed, and making use of the space behind the waiting rooms for the Provender store....
Either line in the yard can store a 2-coach train...
Some cosmetic chairs are needed here and there....
The other thing I remembered after posting the above, is that in latter years, a Tail Lamp Camera was provided at Truro, to give the signaller confirmation of 'Complete With Tail Lamp'. This is, of course, of no use to Larry's layout's era!As far as I can remember (it's a few years now since I retired!), the configuration of the signals and block sections in that part of Cornwall meant that the Truro signaller was not able to see the tail lamp of an up train, until it had passed the box. If the timetable is sparse and there's nothing waiting at the signalbox in rear (latterly all the way back at Roskear Jct - Cambourne), then that's not such a problem. But if Roskear had something to offer forward to Truro, then the section must have been cleared and the only way that can happen on the Up at Truro, is for the guard to confirm to the signaller (as soon as the train has arrived at the platform), that the train is 'complete with tail lamp'. That then means that Truro could accept the next up train from Roskear and turn his block indicator to 'Line Clear'. That then sent an electrical release back to Roskear, enabling him to clear his Up section signal, an essential action if the next train was non-stop and needed a green at the Up Distant, in order to maintain the timetable.
Populating the layout with rolling stock helped a lot yesterday. I left things as they were overnight, but I am simply wedded to having the goods shed at the end of the platform....
Has anyone used the new Hornby magnetic couplings for 4mm scale yet?Looks OK. At least with the coal siding at the back and it's length you don't have to lean over the goods shed to uncouple the wagons.
