Warning: Anyone with an allergy to tension-lock couplings and Peco uncoupling ramps should look away now!
This Peco uncoupling ramp has been assembled as per instructions. It was probably designed for Code 100 track. Its too tall for Code 75 and bullhead and trains will uncouple when
drawn across it.......
Mmmmm naughty...
Two ramps, the upper one is shown after modification...
This image shows the modifications. Four legs removed and 1mm removed from pin holes. Drill the latter so that the holes go right through the ramp....
A second view. Place ramp over base and press in the two plugs. Held in place by applying Mekpak from the ramp top...
If the ramp is too low, add a suitable thickness spacer from Plastikard... The key aim is to draw trains over the ramp without them uncoupling, but they should uncouple when being propelled over the ramp...
