4mm Llanfair
LarryG
The track needs to be sprayed with Howes Sleeper Grime to make an impression on the baseboard, then glued & ballasted down in convenient sections. I didn't have a catchpoint for the coal siding, so a point was used. Empty coal wagons could be pushed by hand into that short stub.....
Update : Bullhead track with flat bottom points below. All flat-bottom in picture above. Sprayed Howes Sleeper Grime....
LarryG
The two sunny days we had at the beginning of the week were too hot for gluing down track using the glue & ballast in one go method. Since then, we've had more than a months rainfall in two days in North Wales. I've noticed water on the railway baseboard via a split roofing board, but there is no chance of investigation yet.
RichardG
I've just done a test area using Ballast Magic. This is a powdered glue you mix with the ballast and set off with a mist of water. My result wasn't strong enough for a permanent installation, but it was strong enough to stay put while I added a dribble of diluted pva. The result has set rock hard so good for a siding, less so for a main line.
LarryG
Track laying today at long last after months of messing about.....
Track laid aside while neat PVA brushed onto baseboard....
Track laid and ballasted before noon.....
All done by late afternoon....
Buildings in place just to see how things looked.....
Ballast was a mix of fine light grey and fine dark brown to give a speckled finish.....
RichardG
Please Larry, are you using the PVA neat to do this or are you adding something into it to help it percolate upwards?
LarryG
It's neat PVA, and the best I've found yet. It is applied thickly with a soft 3/4" brush. Track is lowered onto it and straightened with 3' steel ruler, then ballast poured on. It is firmly tamped with the fingers and hand for a while and the track re-checked in case it had moved. Then strips of 3" x 1" timbers placed on the track with heavy books on top.
Only after the lot is dry do I vacuum off the surplus ballast. This way, the PVA has time to peculate and attach a thicker layer of ballast.
RichardG
Thanks Larry. A few years ago I had a go in a children's workshop run by Mrs Gravett. I soon learnt I was spreading my pva far too meanly. I don't quite know where it all goes, but it pays to be generous. I still have my sample weeds somewhere.
LarryG
The compressor and rarely used Airbrush were set up in the railway shed today. There then followed a dismantling session, which failed to make the Airbrush function. I've had three of these toys and they WILL stop working! So the job of weathering the track with rust washed down from rails to ballast was done with the trusty spraygun...
LarryG
My dislike of the ultra fragile Peco '00' bullhead track has barely been disguised over the years. I've been messing about....
The nearer rail is bullhead, the farther rail being flat bottom....
The nearer rail is flat bottom slid onto bullhead track base. In dreams, I wish Peco had used its flat bottom rail to produce a far stranger product.
LarryG
I have always been happy with the performance and appearance of SMP type J (from Marcway nowadays) and I even married some up to a Peco BH turnout. Might be worth looking at for future projects.
Welcome to Marcway.net
I used Markway bullhead flexible J in pre-Peco bullhead days.. Because of it's thinner sleepers, I put thinner cork under the Peco Streamline points so the rail heights would match. The Markway flexible track is stronger and much easier to lay perfectly straight.
Hayfield1
Larry
Have you ever tried Exactoscale Fast track bases, sleeper thickness 1.6mm. Very easy to lay straight as all webs joined, accepts code 75 bullhead rail
LarryG
Larry
Thanks Hayfield and Captain'. The track bases have come to light too late for the layout now. I was out laying track this morning at 7am before the shed got too hot, and it took an hour to get five feet of double track as straight as possible. After some derailments on bullhead points........ I didn't bother to find out why......... turnouts are now mostly flat bottom.
Captain Kernow
There have been reports of the curved part of Peco bullhead turnouts experiencing gauge narrowing. I understand this has been raised with Peco.
