I seem to remember one of the scenic suppliers producing a "mortar filler" - after a little googlingHi Martyn, The deeply cut grooves used to concern me seeing as I was so used to building with embossed brick plastikard. But I learned to deal with them. That said, I rarely use white mortar now, preferring to use PPC 'dirty black' for mortar and weathering.
I am often thinking along the same lines regarding the visual intensity of my own work, and it reminds me of the same issues involved in painting landscapes. A botanical illustration shows the intricate details of a plant, whereas a group of plants and trees in a garden are more likely to be impressions of the plants our minds perceive the details. We rarely look at art from 3 inches either. As much as I admire the incredible fidelity to the originals that are often depicted by the talented model makers here, I also am inspired by the sense of place depicted in many layouts that are spare with detail.When painting building, I tend to treat them in much the same way as I did locomotives in that if something is barely visible from a few feet away, then make sure it doesn't overwhelm. White mortar can be garish and grey mortar barely worth the effort. Our cameras pick up detail, but I no longer look at thing from 3 inches away at my age...
The station building has just been weathered all over so it is in the sprayshop drying while I get the stink of turps out of the house. No kits left to build so I need to stock up again before Christmas...
Now that is a cracking building Larry. Good to have 'found' you 'over here'. I have missed your Coach excellence.The 'spotty Muldoon's' job of picking out dark bricks was done this morning in cellulose paint for speedy drying....
Then followed the stinky bit picking out the stone colour bricks in celly...
Thanks Phil, and welcome. I used to bang on a bit about coaches ha ha. I've got a GWR K42 parcels to build in 0 gauge if I can find a kit.Now that is a cracking building Larry. Good to have 'found' you 'over here'. I have missed your Coach excellence.
Phil
Geoff, have you looked at Brass Pins as Knobs?Those chimney stacks and pots certainly set the building off Larry, such tremendous modelling. I have also been searching for some door knobs and the only ones I have come across are these........https://www.intentio.shop/index.php?route=product/product&path=18_74&product_id=260
Geoff
