Truck, trucks and more trucks.
I''ve spent a few days tinkering with the GP9 truck sideframes to bring the brake blocks in line with the P48 wheels.
The trucks are scale width (no compromises from Roco again) but they have been designed to fit around a NMRA standard tread width 40'' wheel which means part of frames have been removed to accommodate this.
Original truck frames with P48 wheels. It is not evident from this photograph the brake blocks are in not line with the wheel treads but an oblique angle shows this. Also noticeable in the oblique view is the depth of the frame adjacent to the wheel.
In order to rectify this I removed the brake blocks from the sideframe with a piercing saw.
The white plasticard on the inner brake blocks is there to rebuild part of the block to ensure there is no visible gap between it and the frame when installed.
The modified truck is below (the brakes are temporarily installed and will be straightened and further details added on final reassembly).
Oblique angle. The void left for the NMRA wheels has also been filled to match the sideframe width.
