Ian_C
I've been gradually making up the motion for the 8F and thinking about how to fix the return crank to the driving crankpin.
There's no advice in the instructions and the Geoff Holt books (Wild Swan) don't say anything much about the subject apart from a reference to being quick with the soldering iron. Not sure I fancy my chances of soldering the return crank arm to the end of the crank pin; crank parallel with wheel, phased correctly relative to crankpin and not melting the crankpin insert or clogging up the motion. Besides, how do you get the motion apart after the return crank is soldered on, apart from unsoldering of course? Here's one way of doing it.
The prototype driving crankpin is 6" diameter, or 3.5mm in S7. Much larger than a typical model crankpin, but provides a better opportunity for fixing the return crank to it. The steel crankpin insert in the Slaters S7 wheels is threaded 10BA and provides a good, solid fixing for the pin. There's no reason to change that, so the end of our new crankpin should have a 10BA male thread to match. A 10BA thread has an outside diameter of 1.7mm so it's quite possible to tap a 10BA thread into the end of the 3.5mm crankpin to secure the crank. It should be possible to solder a 10BA stud to the back of the crank. Then we'd have a crank we can screw into the end of the crankpin and secure with a medium strength thread lock. We have to set the angle of the crank correctly relative the crankpin but the chances of getting the threads phased accurately to go tight at the right angle is about zero. If we assumed a worst case of getting the crank tighten 180 degrees from where we wanted it then we'd need to adjust the thread engagement of the crank stud by half a thread pitch, or about 0.17mm. We could put the crankpin back in the lathe and skim a little off the length or we could put a shim on the back of the crank to phase it the other way. So if we machine the crankpin to be a little longer than necessary we can adjust the phase of the crank relatively easily by carefully shortening the pin. Seems plausible, so the next step is to make one and try it out.
The crankpin is machined from steel rod, I'm guessing it's EN1A or similar. You really need to do it in a collet, it's far easier and more accurate than a chuck for these tiny things. Turn down to 3.5mm , then the threaded section to 1.7mm (for a 10BA die) and beyond that a short section at just greater than thread core diameter, 1.4mm will do. The 1.4mm diameter section acts as a lead in for the die so that it starts to cut easily and is lined up nicely before it starts to cut the real thread. Square up the shoulder, under cut the thread, reduce the thread to the correct length. Gets you one of these...
Cut it off and put it back in a collet the other way round. I confess to cheating, I cut it off with a junior hacksaw rather than shred my nerves trying to use a parting off tool. Face it off and take it out of the collet to measure the length of the pin. Put it back into the collet and machine off to the right length, 4mm in this case (being the combined thickness of coupling and connecting rod bosses, plus some clearance, plus some extra length to allow for crank phasing). Dimple with a tiny centre drill then drill 1.4mm (tapping drill for 10BA) to the required depth. Tap 10BA with a taper then a plug tap. There's your crankpin...
The crank is a laminate of an etched and a half etched overlay and they come to about the right scale thickness. It's a Stanier 4 stud fixing and the kit has two different overlays, one correct (ish) and one with a hole in the middle and the 4 studs too far apart. Goodness knows what that's for, so I used the correct (ish) one. There's a hole etched in the main thickness of the crank on the crankpin centre so we can use this to locate a stud. The stud is threaded 10BA to fit the crankpin, has a thin flange to solder to the crank arm and a small spigot to locate in the etched hole. Made this from brass. A picture's worth a thousand more words...
Now we can assemble the parts...
The starting angle of the threads in the wheel crankpin insert, on the crankpin and the return crank stud are uncontrolled and quite random so the angle that the crank arm ends up at relative to the wheel crankpin when everything is tight is also random. This doesn't prevent the model valve gear from working in a fashion ,but we should take the trouble to get the crank arm phasing and throw correct (trailing the crankpin by 90 degrees and with the end of the crank arm at a radius of 8" = 4.7mm on an 8F). We can do this by noting the angle between where the arm ends up and where is should end up. The pitch of a 10BA thread is 0.35mm, which takes a 360 degree rotation of the thread. 90 degrees would be about 0.08mm, and so on. We can use the angle error to calculate how much length to take off the end of the crankpin to get crank arm to sit at the right place when tightened up. Pop the crankpin back in the collet and reduce the length by the amount you calculated. Go cautiously, if you take off too much you either have to make a very thin shim or reduce the length nearly one pitch and have another go, and then you may end up with the pin too short. From this point on the crank arm and crankpin become specific to an individual wheel, so mark them and keep them together. We end up with this...
I plan to use a higher strength thread lock to keep the crankpin in the wheel and a lower strength thread lock to retain the crank arm in the crankpin. That way it should be possible to unscrew the crank arm to take the motion apart. I'm hoping that the cranks arms don't unscrew in normal operation. If the motion and valve gear move freely then the crank arm won't need to transmit much torque. Fingers crossed, we'll see.
Sketches (sorry, not quite BS 8888) from the notebook if anybody wants to adapt it to their own circumstances...
I should add an observation about small taps and dies. I recently bought some budget 10BA and 12 BA taps and dies with this project in mind. They were 'carbon steel' and a real bargain. except they weren't a bargain when it came to using them. The threads and cutting edges were so badly formed that the resulting threads were very poor. I coughed up for some proper HSS taps and dies from Tracy Tools Ltd.
