Never attempted silver soldering. Something I'd have to do outside in the garden as I don't fancy setting fire to our spare bedroom/workshop/home-office!If you modify, silver solder will be your friend.
Or go here for Adrian’s full article.@adrian did a couple of posts about it a while back which helped me.
you can buy the stuff as a paste with flux in a syringe, and you can get some kind of heatproof tiles with holes in that you can pin your parts to, though I use an offcut of marble tile which I drilled holes in with TCT drill bits.
its crucial that you heat the whole job to bright red in a single go, and it “flashes” through the joint, if not, clean up and try again!
