I thought I'd resurrect (
AED required) this long dormant thread as it had the start of the 3F tender so it seemed a fitting place. Having met with Richard and (Northern) Mick of Finney7 at the Leigh show I returned with a new resolve to clear out the erecting shop as I desperately need the space for their imminent releases. One of these items cluttering up the erecting shop being the JLTRT [sic] Midland 3F. As posted earlier the tender has a number of issues so I kept putting off tackling it, I was seriously tempted by the Ragstone tender as a replacement (maybe for another project?) but then it would put the loco to shame so I decided to dive in and build the JLTRT tender as best I could with what was supplied.
So I made the effort of trying to do something each night, even if it was just 5 minutes cutting out a part, and this is the current state. Basically complete as far as I want it, it just needs a good clean up and into the paint shop.
So more or less as supplied except a few tweaks. As posted earlier a new chassis and frames were etched, the axlebox castings supplied were completely the wrong style, the bolts for the keeper plates were aligned vertically so these are some Alan Gibson castings which match much better.
The kit instructions show the steps on a separate hanger plate, whilst there were a couple like this I don't think it was that common. Most steps seemed to be mounted on the frames directly so the instructions got binned and I just worked out things my own way.
Other changes from the kit - the lamp irons are castings but are far too thick and bulky so the rear brackets were made from scrap etch. Some tenders had a small extension plate covering the front vertical handrails - a little bit of 15thou nickel was cut out and soldered in.
The etchings for the coal rails were ok for the rails but the vertical tabs weren't connected in places, they should have been half etched but were actually etched all the way through! So I bent up some brass angle mounting brackets and soldered it all up as a unit with the front coal plate and toolbox.
This could then be glued in as a single unit - this is one item that is usually prone to handling problems but this has made the made them surprisingly resilient.
The other major issue for me was the cast brass brake shoes and hangers. Having gone to all the trouble of making split axles and taking care of insulation sticking bit lumps of brass as close as possible to the wheels didn't strike me as a good idea. As far as I was concerned there were two options either insulate the brake hangers from the frame or replace the brakes with insulating versions. In the past I have always made brake shoes from paxolin sheet for this reason. However this time I decided to use it to practice with Onshape and laser cutting.
I was pleasantly surprised how quick and easy it was. A quick photo using my phone (found a magnifier mode in accessibility settings) was uploaded into OnShape. I then drew a circle and set it as the wheel diameter so that I had something to scale the image to the correct dimensions. I then sketched around the brake shoe.
This was copied a couple of times and tweaked for the different shapes on separate layers, effectively like several etched overlays I was building up the shape from several layers.
I could then easily generate a drawing from this 3D image - export it to a DXF file. Import it into the laser cutter software and cut out the various layers
I made the frame around the outside to align the various layers. So no more than evenings work I had made a test sample for comparison with the brass casting supplied.
I was more than happy with the result so altered the drawing to make 3 brake shoes in one set.
These were then fixed to the hangers and soldered into a unit to clip into the tender frame so that they could be removed to enable the wheels to be removed.
The drawings are available in the public area of OnShape if anyone want to view or use my efforts
Onshape
That's nearly it for modifications - the draw plate buffers to the loco were not supplied but turned from a bit of brass bar.
The plastic tender body has been a real pain I really didn't like it, the curved tops are too fragile, at the rear you can just see I've had problems with it breaking, it's been glued and filled with putty so I just hope it gets hidden under a coat of paint. On the inside along the length of the tender I glued some brass angle and drilled half a dozen holes for tapping 8BA. So the resin body is bolted to the external frame - these are the main components.
Now to tackle the loco!!
