Simon Glidewell
The shape of things to come at St. Mary Hoo. Many here already know about the proposed junction for either Gravesend or Cliffe with its CEGB bisection (leading to a dilapidated coal wharf which may also have a BR connection with working scale overhead) surrounded by extensive salt marsh and mud flats. Welcome to the nightmare that will become Cliffe Junction! This monster with wire tentacles has been an ongoing headache for about one year now, on and (mostly) off. It looks horrible at the moment and is only three quarters complete. Practically no detailing parts have been added; these will appear once I'm satisfied that all stock passes through on every road without exploding in a spectacular blue electrical flash! Knowing my "luck" with electrics that dreaded scenario is about 80% certain to happen. But one has to push the boundaries of 4mm modelling to extremes and experiment with seemingly impossible ideas; I never knew if my third rail would work or not when I first built the layout, but it did and with surprising ease. Here we see the 2 BIL driver trailer being used to test the BR lines; all seems OK there; the hard bit will be the CEGB line cutting through it. The Impetus Hunslet (see below) is sitting on the latter (little does it know). After the right hand BR fork I am contemplating adding another point with an electrified line (simple SR design overhead) that will circle to the right as well, eventually running alongside the power station railway to the coal wharf. The bisected point is seen on its construction board, not a baseboard; I have yet to build these.
