4mm Ruyton Road revival
Joe's Garage
I really like this GNOS 4 wheelers....haven't heard of Prickly Pear but will have a look. Oh no another distraction!
All the best Steve
Julian
2996 Victor
Hi Paul,
I've just been catching up with this thread (and the one over on the Dark Side). Its really wonderful to see this classic layout saved and being given a new lease of life.
I'm very interested in the interlaced sleepering on the new P4 points. I don't know an awful lot about the Shropshire & Montgomeryshire - was that something that they tended to do? (I need to do a bit of research!) I'm planning a Shropshire light railway micro layout to be started soon (baseboards from Grainge & Hodder on order), but not sure whether to go completely freelance or go down my usual "fictional branch of a real railway" route.
I presume that Ruyton Road is remaining part of the S&MLR? How do the GNoS carriages and Black Hawthorn 0-4-0ST fit in?
Thanks for the updates and great pictures, please keep them coming!
All the best, Mark
paulhb
All the best Steve
Julian
Thank you Julian. Prickly Pear is Paul Tasker who appears at a few shows, eg Expo EM and Scaleforum and perhaps a few others. He doesn't have email or a web presence but contact details can be found here - supplier.text - 4mm scale model railway manufacturers and suppliers
He does three GNoSR coaches plus a number of PO wagons in both 4 and 7mm. There is a short article on building the four wheel first in MRJ 153
Regards Paul
paulhb
Hi Paul,
All the best, Mark
Thank you Mark,
There are some photo's that show interlaced points as well as others that indicate otherwise so bit of a mixture! One of my interests in the Highland Railway which extensively used interlaced turnouts so building several for Ruyton was a a good learning experience. They are also in keeping with the idea of a backwater light railway. Ruyton is very much a twig off a branch similar to the Criggion line, and although I do have some more appropriate stock including items that still need to be built I have also taken some liberties! So in my world the GNoSR carriages were sold off by that company to the quarry and used for a quarry workers train. Like wise the Black Hawthorne is used alongside the Sentinal as a quarry engine.
Good luck with your project and looking forward to seeing progress.
Regards Paul
2996 Victor
Thank you Mark,
Regards Paul
Hi Paul,
Many thanks for your post. I'll have to have a closer look at the S&MLR trackwork in my copy of Illustrated History - it's not something I'd thought of but certainly cries out "light railway"! We're the point templates generated on Templot?
I've no issues with massaging history slightly and the GNoS coaches look grand. I love the HL Black Hawthorne, and I'd really like one.
For my light railway project, I've not decided whether to go freelance or to go down your route with a fictional branch line off the S&MLR. I do like those ancient Manning Wardles..... RT Models will help there!
All the best,
Mark
stevehowe
H Paul,
I saw Ruyton Road many times at shows in its original guise and always found it fascinating, good luck with its regeneration! I was interested in the Col. Stephen railcars in the video, any idea as to their origin?
Steve
paulhb
Hi Mark
A good friend did prepare a Templot plan for Ruyton which was useful to determine clearances. The turnouts were however built on standard plans on the bench. First task was to make the crossing as a unit. The timbers were then glued to the plan which had been copied to thick paper, 150gsm if I remember correctly. The straight line timbers were laid first followed by the turnout line ensuring the timbers were correctly orientated. The crossing could then be fixed in place before adding the other rails using gauges. Hopefully the photos make things a bit clearer.
Regards Paul
paulhb
H Paul,
Steve
Thank you Steve.
The Railbus model is from a Taurgem Models kit produced I think in the early eighties and now like the proverbial hens teeth although I did manage to acquire one a few months again on Ebay for a reasonable price.
Regards Paul
2996 Victor
Hi Mark
Regards Paul
Hi Paul,
Many thanks for the explanatory notes - that makes perfect sense and the photos illustrate excellently!
I'm sort-of just getting to grips with Templot (and wow is it clever!) but although I've seen methods of interlacing described I'm no way that far advanced So to see the points constructed this way makes perfect sense.
Many thanks once again and best regards,
Mark
paulhb
Fiddle yard, wiring and cross baseboard connections recently completed so I can test run engines and some stock fully end to end. Or in technical terms have a play! Two controller sockets have been installed and wired in so am able to operate from front or rear.
RodneyS
Member
Joe's Garage
Hi Paul
May I ask for a view from the front and both ends please? I know this may interrupt "playing trains" (sorry!) but it is a very lovely achievable model. I like the little station building and light railway platform.
Thank you
Julian
