Does the Model Company still exist as when I googled it I got some lovely models
............but not the four wheeled kind
I bought it from Bob Barlow when he was running Classic Commercials. I guess our AdrianBS now holds any stocks remaining.
Hi Heather, what typeface should I have used?
Now, there's a knotty question. Someone created a free font for numberplates, but the only ones I can find quickly are for the modern plates. The majority of plates in the 1950s and 1960s were stamped metal, with the letters in bas relief. The letterforms still varied to a degree, but you wouldn't go far wrong to use a Helvetica style face (also known as Swiss or Nimbus Sans). At a pinch you could use Gill Sans or similar, but that's more suited to the earlier painted plates.
It's the shape of the numerals 1, 2 and 0 that stand out, as well as the C, G, R, S and W which would be completely wrong in form when using Arial. Oxford and Classix get away with it at 4mm scale because it's much smaller, but at 7mm scale it kind of jars with me.
I'm a bit of a type geek, from my "real job" of being a graphic designer. Normal people probably wouldn't notice!
The best model plates I've seen were from Classic Commercials, who etched them in stainless steel. Sadly, they may be hard to find now, and were limited to about six different numbers all told. C&L did sell a waterslide transfer sheet of numbers, suitable for the earlier plates which were painted rather than stamped.
Perhaps I should get some data together and sort out some etches. (That's done it. I'll have to do it now.
