Hi Jamie,
Your work is truely inspirational - well done.
You asked about 6-wheel underframes. I am currently making a rake of GNR 6-wheelers in S scale. Like your coaches, the GNR used inside axleguards on the ends and outside axleguards in the centre.
While on holiday a couple of weeks ago, we called in at the Tanfield Railway for a look round and ride. In the stock sidings I discovered a GNR 6-wheeler on its original underframe - there cannot be many of these left.
The end and centre axleguards are to the same pattern: 3/4" thick with a 3/4" square strengthening piece welded round the opening for the axlebox, giving an 1-1/2" bearing surface. The important bit, however is the 1/2" joggle in the axleguard, just below the bottom of the solebar. The end axleguards, bolted to the inside of the solebars are joggled inwards but the centre axleguards are reversed - strengthening piece on the outside, as is the joggle. The centre axleboxes have a large space between the guides, and together with the springs being mounted on links and J hangers, will allow the centre axle to move 4" from side to side.
With no brake gear on the centre wheels, I would think that for a model the amount of movement could be increased a bit.
Here are a couple of pictures of the axleboxes.
Hope this helps,
Susie
