spikey faz
Kempton???might see you at Kempton then Mike
Thanks Dave.Mike,
I'm not sure I have understood your query correctly. The photos show the brake ejector and, as far as I can make out from published photos, the train vacuum pipe runs above the footplate, as per your photos, to the reversing gear box. Beyond that, I suspect it runs below the footplate, out of sight, till it emerges at the cab and then follows the same route as the standard locos.
Regarding the large diameter exhaust steam feed to the exhaust injector, after removal of the Crosti pre-heater, it appears to have been re-routed similar to the standard locos. After sloping up and behind the footplate, in front of the cab, it then turns down (about 45 degrees) and inwards, between the 4th and middle axles' It then runs forward, along the loco centreline, on top of the horizontal frame stretchers.
Not precise details, but hope it helps.
Dave.
Extremely useful pictures. Thank Dave.Mike,
Here's the cheat I used on my 4 mm 9F. Only the visible bit of the exhaust injector feed pipe was modelled, where it swoops down from behind the footplate in between the frames.
On the other side, it forms part of a cluster of pipes coming from the two injectors. In my model these are permanently attached to the chassis.
Dave.
Hi OzzyOHello Mike.
it's daft question time, why are you throwing paint on the frames when you may have some parts to solder to them?
I know that you can see imperfections better with a coat of paint on but it also just makes it a pain to work with.
Nice looking build keep up the good work.
ATB
OzzyO.
