Dave Holt
I'd go along with that except it neither slides nor wears.I would call it a sliding wear plate
Ken
Its purpose is to transfer weight into the truck and keep the truck slide casting central to the loco chassis by means of a substantial central pin. Thus, the only movement between truck and the item in question is a very slight twisting action as the truck moves sideways. From the drawing, it looks like there's a bearing plate between the two parts. The sideways movement and damping is entirely within the truck, controlled by springs or swing links and spring loaded dampers. The central casting can be seen in this photo of a swing link truck.
My models (except the 9F) have a simplified arrangement where the truck frame does slide across the fixed structure, but I doubt any significant wear will take place. The 9F exactly replicates the prototype arrangement apart from the friction dampers.
Dave.
