Rebuilt Crosti 9f
spikey faz
do you use a roller mike or freehand, i always use a piece of card so to overlap the ends
Ken
I do have a set of GW Models rollers, but not needed here as the boiler comes ready rolled. I just had to punch a few rivets out.
I've been adding a few more bits to the boiler as well as cleaning up my soldering. Looks a lot better! I'll take some more pictures soon. I must get back to working on the chassis as well.
chigley
I don't know if you've seen it Mike, but if you google crosti 9f locomotive there's a video 2.45hrs of photos and cine, may be of use.
Ken
chigley
, Hello Mike, i don't know if you are aware i've just been reading my new book on 9f's
92021 retained the original lner return crank and never had the lms/br one. i hope thisis of some use.
Ken
spikey faz
Ken
Hi Ken
Fortunately the kit provides both types of return crank. I shall use the LNER one.
Dave Holt
Have you plans to fill the gap between the top of the pony truck and the loco frames? There was a hefty cast pintle, circular with four ribs, on the real thing.
Dave.
spikey faz
Dave.
Hi Dave
I kind of guessed there would be something like that, but despite my best efforts I've not been able to find any reference pictures of the pintle. Don't suppose you have any links to pictures of said item?
Cheers :thumbs:
Dave Holt
Mike.
In addition to Mick's photos, here is a section of drawing for an Ivatt 2 tank, which shows the same arrangement. Also attached are a photo of my 4 mm scale version under the Ivatt tank and a sketch of the item I made for my 9F. On my locos, the pintle functions exactly as the prototype because the pony truck axle is spring in the truck. If you truck has fixed axles, you'll need to leave clearance to the pintle to allow the truck some vertical movement.
Hope this helps.
Dave.
spikey faz
Mike.
View attachment 167088View attachment 167089View attachment 167090
Hope this helps.
Dave.
That's perfect Dave. :thumbs:
Please explain this comment as I do not know what is meant by pintle nor where that item is fitted.
Thank you, Graham
Dave Holt
Perhaps I've used the wrong word.
Anyway, we're referring to the circular, ribbed, load-bearing structure between the loco chassis and the top plate of the pony truck frame - all as illustrated in the drawing, my sketch and the photo.
Dave.
RichardG
Thank you, Graham
An old English word meaning penis.
Nowadays, a pin or bolt forming the pivot of a hinge.
The pivot of a gun carriage - so quite a substantial pin.
Perhaps, adopted by the railway industry for the pivot of a pony truck?
The old English seems the clearest.
