We all have those moments!
Unknown source - could be copyright
Nowadays you'd probably get pulled over for a load like that.
I did my fair share of roping and sheeting, most if not all factory products where palletised and the nearest I got to
@Osgood's example here was, from memory, palletised peat which was baled in plastic and double stacked on a 40' flatbed trailer. We had to sheet this type of load and use ropes front, back and in between each stack of pallets so as not to split the bales. Other sheet jobs were machinery, some timber and ply or multi piece fabricated parts such as steelwork for the building industry, it being easier and quicker to contain the load without using a multitude of rope and straps as the sheets helped act as a restraint to a certain extent but heavy unbalanced items had to be well strapped and the sheets and a fly sheet put over that to weather proof it.
A filthy job when it was p*****g down with rain!
Not seen a sheeted load for ages, nearly everything now is loaded on curtain siders unless it's a specialist job.
Col.
