Thanks Mike I will look out for the announcement
For a break from removing paint and paper from the ceiling here is a picture I took this morning and it looks like I need a fair bit of guidance as this paint and weathering lark is far harder than waving around a hot stick
First off as I had got the wagons in primer it was time to do something about the rake of coaches I had built. There was one extra I bought from Rob Pulham, which I decided to build and then I could paint them all at once. Well with all the wagons and loco building I have done since the Suburban Brake Third went together far easier than the other coaches. Primer was easy and even the underframe as it's just black everything
It was the maroon, which I admit is Vauxhall Burgundy Red rattle can which has either been patchy like in the photo or runs which necessitated ripping all the paint off the Suburban. Fastening the roof on the Corridor Brake first and then masking off to do roof and then sides just didn't work. So for the Suburban it's roof first and then sides before gluing it together. Time will tell if I can get the maroon right, but little and often seems to be the plan. So far feeling more confident. These two to do and then tackle the other three
