Well, I'm afraid I'm disappointed with this kit.
Fundamentally, the bodysides are approximately 3mm too low when compared to scale, and are also about 2.5mm too short in length.
The ducket moulding, which is nice, is linearily 1mm short in each plane, which leaves a very visible gap if just used as it is.
This picture shows what I mean.
The wheels are 32mm diameter, which is fine for 10mm scale
The mouldings are a bit "heavy" (with the exception of the torpedo vents which are beautiful mouldings) but generally useable.
I really like Roger Leigh and co who made the kit, and will email them my "findings" but am not going to make any more review type comments as I just want to make a brake van not be seen as assassinating someone else's endeavours. I do not think it is easy to get things right, as others continually say, but on the other hand struggle to understand the accumulation of "nearlys" in this kit.
The height issue exacerbates the odd look of the van, especially when combined with the over height concrete end floor sections.
I think it is very hard to talk about all this to the G1 community as one will be seen as a negative nit picker, and so I'm not going to. As I have said before, the kit as supplied will build into a working representation of a brake van and will no doubt satisfy the existing G1 market.
So, on to the build decisions.
I am myself going to correct the height issue by solventing on a new top piece, cutting off the existing "overhangs" at each end, and then the bodyside plank impressions will need re-arranging with filler etc.
I am going to widen the ducket moulding to give a correct fit laterally, but lose the vertical problem by modelling a van with a sheet of metal attached to the bodyside above the ducket. Looking at photographs this was a very common repair from quite early on, which will also differentiate this van from my etched built one.
A final thought re the kit, and I'm afraid it's about price, despite my earlier comment. By the time that I have replaced, altered and not used various parts of the kit, it represents pretty poor value even by G1 standards. Nuff said, at least it has got me off my harris and working on another brake van
