There will only be oneAmazing detail and fantastic quality again Mick, Bring on the Kudos and bling Please!
I strongly suspect this is heading towards the definitive rendition of a BLP (until you better yourself on the next oneEnd of week update on the Bulleid Pacific, very little obvious progress, mostly pipework and fittings and a little sheet work, just waiting on some cab interior ribbing etches to finish that area off.
Most of the week was spent in 3D sorting out the front end of the roof, optimizing orientation and shape to fit the metal casing with the minimal of visible joints/filling. That's all done now so just need to fill the gap between front and rear test sections, add details and set up for the mega 14hr print.
I'm still waiting for the new casing etches to arrive at the end of the month, they have the new front plate with the smoke box door opening raised to the correct height. It's a simple shape so I may well get bored and whip this one off and hand cut a new one in the mean time, that'll leave one casing complete for another model. Some one asked if there was a chance of a Giesl option, it was churlish not to try, it still needs tweaking until I'm happy with the shape, but yes, a Giesl option is viable which will also need a new smoke box interior module.
The two front ends here were not at optimum quality for detail, they're just to test for fit. You'll see really bad layering on the front cowl, that gets minimized at the optimum angle and even more so if I lowered the layer depth to say 30 or 10 microns. Frankly it's on a smooth surface with no surface detail (planned that way, I call it pushing the error to an area easiest to clean up ) that it's easier to just sand smooth with wet n dry.
No quite sure there, I'm sure there are many other good renditions out there, I'm just doing things a little different.I strongly suspect this is heading towards the definitive rendition of a BLP (until you better yourself on the next one). The Giesl option really makes it stand out as something special IMO. Absolutely cracking work, I hope you're pleased with what you're achieving Mick.
Indeed, I got a bit of a surprise when I tried to clean my first print that used the whole build volume. My usual method at the time of spraying alcohol on the part rather than dunking it wasn't practical. I eventually settled on dunking in the tub that comes with the wash'n'cure, which I don't use for cleaning in any other situation. Fortunately, the wash'n'cure tub was full of cleaned and reclaimed alcohol, so I dropped the part in and let it soak. I would hate to have to use that much fresh alcohol to clean something.a tub big enough to wash it in
Folks, this is why you spend weeks feeding the bin monster with test shots. The real McCoy, 23 + hour print perfectly straight with imperceptible surface defects or artifacts <smug mode ON>.
It did highlight two problems I've not encountered before, a tub big enough to wash it in and it barely fits in the curing cabinet.
The slight banding you can see is colour and not tactile, Fast Navy Grey (FNG) needs to be well stirred before use and starts to separate after about 6-8 hours. With long (time duration) prints the build plate is clear of the vat so you're relying on the actual printed part moving to agitate the resin, it's not very effective so you get a marbling in colour which varies from white to the main dark grey colour.
Tomorrow it'll get all the sacrificial surfaces cleaned up and a blow over in filler primer.
AppreciatedMick,
that is truely impressive. Obviously great skill by you but, it is probably the best piece of advertising for the printer. Blown away. Please bring it to our next get together.
I have two tubs, the primary one for straight off the plate, thick dark grey by now, 20-30 prints no problem. Second tub is clean fresh stuff, same again 20-30 prints and just tuning a darker shade now.I use my wash’n’cure every time. I’m going to filter the alcohol (which is FNG coloured) at some point. I must have washed 10 or 15 prints in it so far. I did top it up, a little, over Christmas, and I do use the long tongs to retrieve stuff that falls off the build plate.
Simond,I use my wash’n’cure every time. I’m going to filter the alcohol (which is FNG coloured) at some point. I must have washed 10 or 15 prints in it so far. I did top it up, a little, over Christmas, and I do use the long tongs to retrieve stuff that falls off the build plate.
You don't need the sun, decant into a smaller container, stick that in your cure station, assuming you have one, 30 mins later should be nice and clean.Thanks Mick,
I'll filter it after leaving it in the sun. That'll not be this week, looking ouit of the window!
