It's a DCC weekend for a couple of Loveless models. First up is the A4, nothing untoward until you try and fit the V5L chip. There really isn't a lot of room in here despite the huge casing, above the motor is a massive weight and the smokebox is enclosed with a fake tube plate and floor which hold a smoke generator I think, it's not wired and the speaker has been removed as well.
I tried to fit the adapter board with screw terminals, no chance, then the smaller one with soldered tabs, still no chance; so ended up making a 3D support and soldering direct to the pins.
The clip has a lip at the top to hold the board in place, the base is simply a tight fit with a thin strip of double sided tape to stop it wobbling about.
For future builds I'll try and find some of those two square pin plugs I've seen kicking around, the PCD should match the chip pins and I only need six connections and all are pared up next to each other.
The brass strip at the front is just a backup to stop the speaker swinging, it's quite tight on the one fixing screw but the clip is a plan B basically.
Having sorted all that it was set up and tested and for the hell of it, some studio shots for the archives.
Next up an A3, I suspect it'll be totally different inside.
