Small update on the King Arthur rebuild, sometimes things do not go to plan.
The Faulhaber motor sent me on a merry goose chase with DCC, it really didn't like my old H&M DC controller at around 45% speed, the motor bucked and stuttered like mad, above or below that speed it was fine, not had a coreless motor do that before.
Slapped a basic DC set up in and it was smooth right through, almost. Low speed was a bit erratic so used the DCC motor tuning set up in ESU chips, much better but still not really smooth below 10% speed. Couple of days running round in circles and decided to see if the ESU Lokprogrammer software was any better than sprog.
Well done ESU, they had a preset motor set up for Faulhabers, whilst the auto tune was close the ESU preset set up was spot on, now all nice and smooth. Lokprogrammer front and center, Sprog stored safe as a back up system.
Then it was a case of just running it and running it and running it to bed all the motion and bearings in.
Re assembly began a few days ago, still a lot of bright work to add and polish up but it's getting there; my silver pen had dried out (new one arrives tomorrow, well done amazon for their 24hr service) so then I can silver up the smoke box dart, lugs and some cab handles.
There are caps to go over the Slaters wheel fixing screws which I'll tend to in due course, on top of that there's glazing and internal polished bezels to fit, plus the final polished boiler pipework. I have some miniature slinky hose for the vacuum pipework and the steam pipe and fitting to fit to the tender as well as the remaining tool box; there were a few blemishes on the previous one so reprinted and now letting the paint harden before fitting.
There is however one great big elephant in the room, front steps, they are cranked and have half etched lines to aid bending, well as was to be expected one of them fractured; despite the half etch slot being filled with reinforcing solder it still failed.
You can only really fix it one way, clean it all back and add a backing strap, a butt joint is never going to work, of course doing one then makes the other look odd, so you have to do both sides. The real engines do have some sort of brace or stay down there so it's not totally un-prototypical. It's all repaired now and they'll never get bent or snapped off again (should have done this in the beginning truth be told....hindsight and all that....)
It'll go back to Warren once everything else is done and he'll work his magic with some extra sharp crayons and it'll all look tickity boo.
Coal needs to be added and then couplings, I've used the CPL hooks but the actual couplings I'm going to see if there are any other alternatives available at Doncaster.
