Taking a break from the Garratt and it's back to the Masterpiece Princess Coronation.
The plan was to do all new etched cab, so grabbing the old parts I sallied forth in CAD, it soon became apparent that the bits from the model were so distorted that measuring would be next to useless, grabbing the works drawings showed other measurement tweaks would be needed, nothing much, just a smidge here and there.
Problem is a smidge is make or break when getting bit to fits something already made, you end up over extending the etch edges and filing back to suit where it touches.......if you're going to do all that then you might as well roll your own.
Out with the crayons and sharp adult tools a new cab front was worked up, it fits the model well, still one or two gaps to iron out but those will go once the whole lot is lowered about 0.4 mm.
It's much easier to trim and work on the new front with it attached to the roof, I got pretty close on it's own but it keeps flexing and you never know if you're taking material off that doesn't need it.
Once the fit is right and all square then I'll tend to the cab window top edges, they're just a basic angle until I know the roof is all square and in the right place, then I'll match that slope and make the two parallel.
I'll do an inner core skin, one that holds the seats and window frames, then ponder the final outer skin, I may still opt for an etch but I do have a Finney7 kit of my own so I might filch the sides and see if they fit or not, then worry about getting new etches for that at some point in the future.
I'll also scratch build the rear wall as well and that'll allow the cab turn in's and doors to be fitted up.
