Hello folks, more 72xx I'm afraid.
Revised the radial springing, should of done it like this in the first place and not taken the lazy mans path.....lesson learned. Basically an upturned wire U over which the springs fit.
Two tabs on the frames and a bridging piece above with two short sections of brass tube. Simply flip the piece over and make sure the tops of the springs are over the tubes, slip the bridging piece under the tabs and it's all held in place.
I will secure the bridging piece after paint and I'm sure I have the right spring pressure, but for now it's easy to flip in and out during the build.
The test run of the resin sand boxes went okay, the sacrificial edge hasn't been cleaned off as a few issues became apparent quite quickly. First, they are scale size, the frame width isn't so they're visually too close together, I will trim their width a mm or so; they'll be scale under width but will visually look better.
On the bottom the outlet spigot and flange is slightly deformed, I'll probably revise this and make that a separate piece to get them perfect.
The biggest blunder is the pony truck obscures the outlet, they will need moving outboard, my mistake on the master by not moving the outlet position.
On the plus side the actuating arm gland plate and filler cap with undercut came out very well, something the old printer could never do, so not all a waste of time.
Finally the embryonic footplate was bashed up, the frame extensions up front fitted just nicely around the sand boxes, mind there is a small gap to fill where the splasher will be to close up the gap with the frame.
Hopefully I'll add the splashers tomorrow and begin building up the front end with the raised section over the cylinders and dropped front footplate section.
