Short week this week, day out tomorrow and Friday prep and travel to Stafford. I did manage to get to grips with the new project, a DA Princess Royal, very tight date line on this, as it left the factory.
The whole kit is nickel silver so that's nice, but will make forming some bends a little more physical I'm sure.
First up the tender, one of the rare Stanier 4000G straight sided tenders, only three built as far as I know and only used for a short time I believe, two went to Princess Royals, the third went with Royal Scot on tour to the US, what happened to them later I've no idea....as yet.
A quick start on the tender chassis and already some things need sorting, the brake gear is very 2D so I'm going to have to rebuild quite a bit of that and the front inner chassis won't work once we put the new front end in to hold all the brake weight shafts and trunnions. The inner chassis was easy to cut back and add the new base for the plate work and brake cylinder to come.
The other issue is the water scoop and I blindly stuck it in where the kit had holes for it, never gave it a second thought until I tried to add the brake beams and transverse stay, it's 10 mm out of place, not only that, the stay that holds the plates for the shaft to work the scoop is also out of place. End result, split the chassis down, remove the stay, rebuild and move the scoop. I also added the braces to the scoop stand to give the eye something to look at when peering in there.
Finally last this this evening, the bases for the footplate was whizzed up, nothing untoward here but it's tight behind the side plates with S7 wheels and leaves bare minimum side play.
