LOL, I dare not open the Seven Models Brit and 9F boxesRemarkable research and after all that Mick - I'll try not to complain about my 9Fs too much!
I already know just from photos of other peoples models that both kits suffer terribly with either the firebox shape or throat plate clothing, or, both. I already know the Princess is going to need work after Nicks detailed research and I suspect the Jubilee and A1 under the desk will be the same.There probably isn't utopia in the kit market, except maybe MOK, Finney or MMP and one must accept you get what you pay for, but the errors so far on the A3 are not anorak details, but fundamental basic shapes and sizes, overall the DA kits go together really well and 90% of it represents the real thing rather well
The Problem is, knowledge is often detrimental, one feels obliged to replicate ones research as far as is reasonably practicable, thus one tends to end up in a rather sticky mess, rather more quickly than one appreciates
After a sleepless night I re-looked at the A3 footplate and measured up against the GA, my previous thoughts on the footplate being the cause is mis-founded, the footplate was the right shape but it's the frames that are wrong, see attached.
The red line is the correct frame top shape, the DA kit splits the forward frame section above the footplate by the smoke box saddle and is shown green, this is the correct shape and if you follow the top green line it tracks the red line of the 1:1 frames. However, the DA frames follow the blue line which is also the foot plate line, note how it sweeps up above the frame line over the drivers by about 4", it was this gap I was trying to replicate as it can be seen under the boiler.
And on the model
The red line is the correct frame shape, from the GA the frame depth is 3'.9" which in 7 mm is a depth of 26.2 mm, the kit is 28.0 mm deep.
By pushing up the centre section on the DA kit to get the gap I made the drop link bracket too high, it's still the wrong shape mind, and once the splashers are added their crowns will impact the boiler, a bodge on a bodge and in the end a right fine pickle.
So, the footplate is now formed correctly and the next stage is to finish the cylinder wrappers and solder that assembly in to add strength at the front end, then remove the wheels and new spacers, attack the top of the frames with a big file and reduce the height and then put it all back together again and deal with the other bits as I go along. Fortunately other than rivets near the top, all the other holes and openings seem to have been measured from the base of the frames so will still end up in the right place
