Richard,
Thanks, I was kinda coming round to the fact that I'll have to 'cut in' the tabs, the painfull part is that the 08 doors all need four tabs and some need six. These are half etched to represent the thinner stamping at the handles and hinges. With hindsight it may be better to have the doors and half etch 'fingers' completely separate from the carrier etch and just two or three bespoke tabs that are not retained as I currently have, will look at how hard that is to achieve, might actaully be easier to rework that way than to cut in all the current tabs.
Class 40, yes I do hope to make an inner chassis as well for CSB suspension. The front wheel on the class 40 is actually a pony truck in 1:1, it is controlled by swing links which to get the require length and thus radius are extended in front of the buffer beam to a pivot outside of the loco, these pivots are covered by those two domes at the bottom of the buffer beam, I'll dig some photos out tonight when I get home if your interested.
JLTRT use a radial sliding block, much like a Cartazzi truck, most other kits use a pony truck as you noted on the Heljan, 4 and 7mm, neither are true to the real deal. I'm not sure of the 'psuedo' radius that the real swing links give but at a guess I'd put the pivot theoretical pivot point back behind the first driver and maybe even close to the middle of the bogie.
Mine wont be prototypical either as I'm going to try some sort of bodge that uses CSB not only to contol vertical springing but also to provide lateral force as well, a sort fo free floating axle held in place simply by the two CSB wires. I found on the 08 that the thinner etch used by MMP allowed the Slaters brass axle boxes to float laterally, the application of the CSB then dampened that float and provides a nice (all be it small - 0.2/3mm) cushion.
I only have about 2mm clearance on my bogie and can now see why EE made the bogie frames kick wider around the front pony LOL, I've only got just over 1mm on the drivers between S7 and side frames which are scale width, it's amazing how tight these gaps are on the real deal!. That gap is made smaller by the side sheets of the mud guards if they are placed true to prototype, so I may need a little modellers license here to give more leeway between wheel rims and mud guards.
Hopefully another update tonight both for the 08 and 40 etches, PPD had some insight into laying out the etch to save money, long thin ones are cheaper than square ones, the longest side being 285mm or the long side of an A4 sheet, so it's best to lay your A5 sheets side by side letter box style rather than on top of each other packing box style, a picture would explain so much better LOL but lack of such basic tools here precludes that!
Kindest
