To check my understanding, the foundation layer is foam underlay and that foam underlay is coloured with a mix of Greenscene texture paints. The painted foam is then covered with a mix of Woodland scenics and garden soil (why not one of the WS soil products?).
How is the WS cinders "fixed" to the underlay?
thanks, Graham
Hi Graham,
Sorry if you.have been mislead. I will try to explain in detail.
I will refer to underlay as that which you may use beneath the track, and foam underlay which is used on top of any previous underlay.
If you plan to use a track underlay on your layout ( Cork, foam, w.h.y ) then lay this over the whole of the area you wish the yard to be (track and yard area.) After laying the track, lay the foam underlay (either on top of any underlay you may have used, or directly on the baseboard surface if you have not) where you want the yard surface to be. Butt this underlay up to the sleeper ends. Using 3mm thick material will be the same height as the tops of the sleepers. This will give the sleepers that "buried" look, as we don't want a ballast shoulder in the goods yard. The ballast (W.S and seived garden soil) is then laid between the sleepers as normal. The side of the track underlay is butted up to is also ballasted, but only in the voids between the sleepers up to the edge of the underlay. Make sure the ballast is level with the top of the sleepers. The ballast should now be more or less level with the top of the foam underlay.
The Greenscenes textured "gunge" is then stippled onto the foam underlay and blended in where the track ballast meets the foam underlay, which represents the actual yard surface.
I used sieved garden soil rather then W.S, as I have a free lifetime supply!
Hope this helps, Please ask if you have any queries.
regards
