4mm Ivatt Class 2, 2-6-2 tank in P4
Dave Holt
Peter, as you say, a bit late for my model, but thanks for posting. Your detailed photo stash might be very helpful for others who are planning to model one of these rather attractive locos. Perhaps in the "Resources" section?
Tony - :))
Dave.
Dave Holt
The loco is now back home, having been collected at Scalefour Crewe on Saturday. It has been painted, lined and weathered by my friend David Clarke, based on a photo of a sister loco taken at Lees Shed, Oldham, in the mid 1950s.
Jobs still to do include the large diameter buffer heads, cab glazing, inserting the cab inside detail and adding some real coal to the moulded version in the bunker.
Dave.
Dave Holt
The 18" buffer heads, described earlier, have been fitted. I suppose that I should really change the BR Standard buffers to be the same.
The cab interior has been temporarily fitted and real coal added on top of the plastic moulding.
I had hoped to cut down the Bachmann glazing inserts and re-use. However, the side windows are rippled and for the spectacles, there are three LH and only one RH. Not sure how the factory managed to fit them. Anyway, it means new windows will have to be cut from suitable sheet material with the attendant difficulty of getting a good, tight fit in the openings. Grrrr.
Dave.
Dave Holt
No problem, Tony. Shots of good looking models are always welcome.
The Bachmann body is very accurate, dimensionally, if somewhat lacking and crude in some details. I built a BR Standard version of the 4 mm DJH kit and found the cab to be too short, particularly the width of the door opening. My solution was to split the etch and stretch to door to make the cab length correct. This did mean the door opening is now too wide rather than narrow and a replacement roof was required.
Thanks Dave, yes I'll be using canopy glue but still have to get the windows something like to hold in place whilst the glue sets. With etched cabs, I usually cheat by simply fixing the glazing to the inside surface, so the actual size and shape isn't too critical but that's not possible here.
Dave.
Dave Holt
I've managed to make and fit the side windows and front spectacles, on both sides, without too much problem, as seen below. However, for whatever reason I just don't seem able to get the size and shape of the rear spectacles quite right. I've had a go at four so far and none quite right, so there's a (hopefully) temporary loss of enthusiasm.
At present, the windows have been attached using Humbrol Clearfix canopy glue, applied round the openings before inserting the glazing. I'm wondering if it might be a good idea to try to run a fillet of diluted Micro Kristal Klear round the inside to reinforce the joints.
Dave.
Dave Holt
That would be one way round. That said, not a single photo of these locos working on the branch show the spectacle plate windows open - in an area where it reputedly rain 366 days a year and summer doesn't arrive till the end of September and winter starts in August, even an enclosed cab wasn't too oppressive.
Anyway, that consideration isn't necessary because I managed to make two rear spectacle windows to an acceptable shape and these are now secured in place.
All the window joints have been reinforced by applying a pool of Mikro Kristal Klear to the inside and then mopping up the excess using a dry brush and capillary action. Just waiting for it to fully dry now.
Dave.
