OK, back to the project!
I have just sent an email off to KEOP, at logcabins.co.uk to get an updated cost estimate. The dimensions stay the same but the windows and doors have changed a bit. Here is my current specification:
Footprint
5m x 6m on 5.2m x 6.2m slab foundation
Style
Classic roof 19° slope
Apex orientation parallel to 5m sides
One internal open space
45 mm log thickness
Front wall
6m wide with up and over metal (optional brown) garage door UT to left, no windows. No overhang.
Rear wall
6m wide, no windows, no overhang
Left side wall
5m wide, two VRL dg windows, uniformly spaced. Gutter and down pipe option.
Right side wall
5m wide, one VDD12 dg French door near right end, one or two VRG dg windows uniformly spaced to left of French door. Gutter and down pipe option. (Comment - the French doors will allow easy movement of larger components to a small terrace outside as well as the existing workshop which will be used mainly for paint spraying. This terraced area will be separate from the rest of the garden.)
Roof
Red felt shingles
The placement of doors and windows won't make much sense from this list but they take into account various other structures and pathways around the building.
The red roof will match the house (red clay tiles, recently de-mossed).
KEOP strongly recommend Sandolin products so I have been watching their videos this afternoon. The first thing that needs to be done is to apply preservative, then the decorative coating(s). It is recommended that the interior walls be treated much the same way as the exterior walls in that it is a garage and therefore can be humid at times. Coating both outside and inside will prevent warping. The choice of external colour(s) has yet to be made but a light white colour would be best for light distribution within the interior.
Although the modular rubber matting is quite expensive, this seems to be a very worthwhile addition. And with 30 sq. meters of roof, guttering will provide plenty of run off for gardening water (two butts came with the property).
I have a qualified electrician lined up to do the wiring. This will include enough amperage for oil filled radiator heating and power tools such as a table saw, etc.
Now, timing! Once the order for the building is submitted and a deposit paid, the waiting period for delivery is around 12 weeks. As we hope to be off to France when the respective governments agree to us doing so, it would make sense to have the kit delivered on our return, which we plan to be in mid-July. Although August can be a rainy month, we are hoping that much of the construction and painting can be done then. We will probably have KEOP do the construction (it's inexpensive and is normally done in one working day!)
My next research will be the fitting out of the workshop and deciding what goes where and what may need to be acquired. I am hoping not too much!
