@Osgood
Hi Tony,
If you use the Templot 3D-printed filing jigs the vee rails will fit together very snugly and do not strictly need fixing. In the FDM-printed bases with loose-jaw chairs the dropper wires (24swg TCW) are attached to the rails before assembling them, and the rails are effectively fixed by pushing the dropper wire into the dropper wire retaining ridges:
And if necessary retained there with some suitable sealant, such as children's modelling clay from the pound shop. This handy stuff looks and feels like brightly coloured Blu-Tack, with the difference that if left for a few days it loses its stickiness and dries out to a blob of rubbery material. Which is ideal for sealing things but can be removed easily if necessary.
Dropper wire:
RS PRO 0.56mm Tinned Copper Wire, 24 AWG 91.3m Reel | RS
Here is my provisional jig for soldering dropper wires to the underside of rail, where they will be almost invisible. As you can see no expense has been spared:
Four 2p coins glued to a bit of wood with a gap between them for the rail. A 1p coin glued on top to support the dropper wire. A blob of Blu-Tack to stop the rail sliding, and another blob to hold the wire while it is soldered. The ink marks on the rail show the chair positions which must be avoided, and also confirm you have the rail upside down. It works fine, but I'm intending to create a proper resin-printed equivalent.
But if preferred the vee can be fixed solid after assembly:
Resin chairs: these will resist soldering temperatures briefly, so the vee can be soldered in situ. The neatest result is using low-temperature
SMT paste (138degC). It's expensive, but a tub lasts forever if kept in the fridge, and it is useful for lots of modelling jobs:
SMDLTLFP50T3 | CHIPQUIK SMD LTLF Lead Free Solder Paste, 50g Tub | RS
Just a smear with a cocktail stick into the web of the (cleaned) point rail after inserting it in place. Slide the splice rail up to it and touch the rails with a dry soldering iron. The SMT paste will flash and lock the vee rails together invisibly.
FDM (COT) chairs: same process but using
epoxy adhesive instead. FDM filament won't resist soldering temperatures.
cheers,
Martin.
