it does look rather purposeful. What engine?
Ford 100E sidevalve...1172cc, twin SU carbs, indeterminate cam, Aquaplane head & manifold and valve cover, separate, external spin on oil filter system.
When I had finally got the cobbled-up SUs sorted [cobbled in the USA]..I took it to a nearby rural rolling road tuner [of the foot long screwdriver brigade]..he sorted the needles out using the expedient of spinning them in a drill, and eyeballing with a bit of emery cloth.
Ended up with between 50 & 55 bhp at the rear wheels. Probably would have been similar if it had retained its blower....but I do have a Shorrock-type blower to hand, if I can be bothered.
It was blown, at vast expense [for the time] during the 1980's....The engine still retains the toothed bottom pulley, and the holes in the front plate for the blower bracketry.
A Dellow was a marvelous concept for a transatlantic punt over the internet. I had no issue whatsoever about the engine & running gear, regardless, since all Ford sidevalve spares are available from the Ford Sidevalve owners Club..
There were one or two pure Dellow bits...steering box [slightly less than a turn, lock to lock...very quick steering]...and the propshaft & torque tube length [shorter than Ford's Pop items.]
The rocket tube chassis [see website?] is unlikely to deteriorate, being of chrome moly steel..
The fuel tank holds 15 gallons!
I cannot afford to fill it!
Nearly 3/4s of the car's total weight is over the rear wheels.
One won the Daily Mirror Rally [forerunner of the RAC rally?]...Knowing what the car is like to drive & live with, I can't begin to imagine the difficulties the navigator had, plotting the route & reading a map? In an open car, where one's left elbow would have likely been outside?
On mine, the gearlever is on the passenger side!
The external handbrake is exactly that...a brake operated by hand. It is more effective at stopping the car from 60 mph than the footbrake.....Probably because it is a longer lever?
The parking brake is the Ford item, under the dash...and used once parked, since to apply it one needs to push hard on the footbrake first. This then locks everything up. On mine, it also means the brake lights are then permanently lit, so I would need to turn off the battery isolator [behind seats.] So, I rarely use it! If parking I tend to leave it in gear, and pull on the outside handbrake, locking it in place [it has no ratchet, obviously..it's a hand brake!] using the hook off a busted bungee strap. No way can the car be moved, even if out of gear, with the rear brakes hard on! From the factory, the outside hand-operated brake would be wired up so that, pulling the lever rearwards operated the rear brakes, and pushing the lever forwards operated the front brakes!
No wonder Dellows were hard to beat on the seafront autotests at Southport and Fleetwood? [There are old B&W movies on tinternet shwig the rapid progress of a Dellow round an autotest , compared to others.]
Mine has been trialling in my ownership....its only my feeble body pains , and the cost of fuel that prevent me doing more....That, and finding a willing passenger!
The Dellows are incredibly strong cars....and can be bounced around off-tarmac with impunity.
Dellows can also now compete in the pre-war class for trials..[bless the VSCC for their insights]... The MGOC trials{?} allow Dellows, but they are in a class of their own....for some reason.
I'd compete in the pre-war class, but to 'qualify' means finding a pair or three, suitable crossply tyres for the rear wheels.
Avons are useless, tread-pattern wise [Blockleys are useless on wet grass]...Has anyone seen the price of larger cross ply tyres recently?
[550/600 x 16 I'd need] I paid less than the cost of a tyre for my complete daily driver!
For the rears I use normally, Michelin XCS taxi tyres.....a bit stiff for a car weighing less than half a ton, bt decent rubber & tread pattern.
I also have a pair of Nankang FT-7 radials, mounted with the white lettering inwards ....which have been accepted for the MCC/ACTC tyre lists, thankfully. They have fewer plies than the taxi tyres, so are more flexible and amenable to lowering of tyre pressures in order to cope with mud & stuff.
I have one crossply Firestone....the cost of which is more than a set of 4 tyres for my daily driver!
The front wheels of the Dellow [16 inchers, or 17's if I so wish] are all shod with Avon tourists....which are too small in cross section to run on the rear.
I have the Dellow owners worksheet.....only need 17psi in the front tyres!
Sorry about the ramble...
