Wot! No posts since August! Well Telford came and went followed by a couple of business trips but I am now back in the swing of things. I'll post a better update later but these show progress.
Frames went together nicely. No real issues with the running plate: just the usual pfaff in forming the curved sections.
The firebox wrapper was a bit long and had to be filed back to the former, but otherwise the smokebox/boiler/firebox and cab assemblies went together well. The cab is secure but the rest are just positioned in this photo.
I had fun making a support for the bracket that stops the ABC gearbox from rotating.
Work is now underway on the brake gear. The only issue here was that the pull rod from the crank to the rear beam was a bit long and had to be shortened.
It's good to be back at the workbench again.
